Bowtner
I am having problems with my tailgate, its stuck in the unlock position. I've had the car about 5 years and the lock has been fine until Wednesday. I opened it but when I went to close it the lock stayed in the unlock position.
I have took the trim off and and a sparky friend has checked all the wiring terminals that go to the lock. One of the terminals is only showing a 200 milli-volt change to the motor terminals when the key is turned in the lock. Could this be a bad earth or a break in the wiring? :think: Has anyone else had this problem? Thanks in advance Bowtner
Fixed it. I decided it must be a motor problem so started to remove it after a couple of turns on one of the fixing screws the motor released. put it all back together and its as good as new. Happy days:funk:
