brad1
hi there
i have just got hold of a tdi tuning box. just need help where it goes. this is my mates engine which the box plugs in at the front part of the engine.
and this is my engine ^
and help greatly appreciated
the tuning box
this is the tuning box
hope this helps
have you got a link as to where i can buy one, ebay etc. also where abouts on the picture of my engine should it go
cheers
i use a psi tuning box on my 110 tdi same engine as yours mate and don't have any trouble at all better power no smoke better fuel economy and its been on over a year now but they are over £250 new and i work for vw dealer and it don't bring up fault codes because I've checked:drool:
There are some tuning boxes which do a reasonable job, but as has been pointed out they can be expensive. I've seen some priced at over £500, which really is ridiculous. That's the cost of 2 remaps!
As a cheap boost do a google serch for "Evry mod" and spend a couple of quid making your own tuning box. It'll be as good as the cheap tuning boxes off ebay etc. and you'll learn a bit about your car in the process. But I'd be spending a couple of hundred quid and getting a half decent remap if I was you.
Or do the "evry mod" and save the money for the damage your car will likely incur from a cheap resistor jammed into your electrics.
T/B's are ok, but remaps are better. I've had both on a previous car and they are 2 different animals.
Get a remap for the same money as a new TB and have peice of mind that you bought the best you could afford and can go back to a company for support if you have problems.
If that is not clear enough tuning boxes make your computer very inaccurate too so dont waste your time with them, you get a really lumpy idle to boot.
Glynn
