i've had to replace the window regulator and noticed that when the window dropped inside the door it landed on / hit a large square piece of black polystyrene.
during the impact hit has split it and deformed it a little and more it from its original location.
i thought i'd moved it back to where it was, refitted the inner metal door panel, new regulator, glass etc....checked the widow operated fully and it doesn't go all the way down, stopping about 80mm from the top of the door.![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
i'm assuming that this polystyrene block is in the way and preventing the window from fully opening, as the window stops suddenly upon an obstruction rather than slowly, as if its all out of alignment and gradually pressing up against something
basically i won't to know if i can take out this block of polystyrene, what is its purpose?
is it for sound deadening / to stop the door skin from vibrating like a drum skin?
is it there purely to stop the glass from shattering when the window does fall into the door?
...the window falls into the door when the plastic clips in the regulator assembly fail.
