Temperature problem
davids5438
Recently my cupra 1.8t has developed a temperature problem. On starting from cold the temperature gauge rises to the normal 90 but then it starts to increase to top scale and the high temperature alarm comes on. If I then stop the car but leave it ticking over the temperature gauge returns to 90.
davids5438
It is a 53 reg plate, I have had the car for 14 months and it has done 24000 miles. As far as I know it is the original water pump
davids5438
The fans come on when the temperature rises and switch off when it is idling.
When it is idling the temperature is bang on 90
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
when mine went i was ok in traffic... but once moving at any decent speed the temp rose until the alarm went off.
due to the location of the pump most get there cam belts/tensioners changed at the same time. i got charged 350 the lot which included a metal water pump impellor which wont fail like the plastic stock one.
get it sorted mate as overheating is very bad for your engine.
davids5438
thanks for all the help
to all those who suggested it was the water pump, you were correct :)
my car went in for repair on monday. £218 for metal impellar pump, timing belt and tensioners. Back to normal :D
Thanks again for allyour help
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
less than 150 here mate, all sorted on tuesday past also, nylon head had completely disintegrated. Funny that since fitting new timing belt etc also, im not boosting over 20psi where it simply didnt in the past (i put it down to the larger fmic robbing a psi or two.)
