Things to change when fitting a new clutch?
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Maybe be buying a new clutch soon, is there anything else thats worth changing at the same time?
thanks in advance
cupramillo
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Im getting a spec stage 3 clutch and it comes with a balanced g60 flywheel. So the master cylinder would be worth changing? What about the slave?
Nov 2, 2004
9,335
South Wales
WHy does he need to change the master cylinder?
If i was doing a new clutch on an ibiza i would do vr6 clutch, g60 flywheel, flywheel bolts and release bearing. I'd also bleed the clutch as its easy to do.
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
I should be getting a spec stage 3 clutch with a g60 SMFW soon for a very good pirce, otherwise i would have gone v6/g60. So theres no point doing the master cylinder? Think is about 6months afo i had a sticky clutch pedal, turned out the garage had left the bleed nipple off the master cylinder, but im guessing its still on the original cylinder.
Nov 2, 2004
9,335
South Wales
fyi, i just bought new master and slave cylinders for mine:
Master Cylinder 6K2721401A £46.90 + VAT
Slave Cylinder 1J0721261J £31.05 + VAT
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
thing is when i got my sachs stg3 done advice i was given was to get it all done at same time as clutch work labour isnt cheap and so it can all mate nicely, i meant the release bearing not the master cylinder get confused lol so bought cutch dual mass flywheel and release bearing mind you i paid 80 for the work to be lol
