i have seen standard smic logs at high rpm in the late 60's early 70's on a mapped cupra after a couple of runs, thats with a outside temp of mid 20's so it seems to be cooling better than that, summertime will tell exactly how good it is
will be interesting to see requested vs actual boost logs too :)
regarding the compensation if their is pressure loss, depends on what pressure your running your turbo at the min, you dont want to crank it up too high to compensate otherwise it will go bang
them logs done in 4th gear?
lol well atleast there are some logs with this one to help its case!! i thought there would be alot of posts on this thread but it seems it hasnt had alot of interest! maybe we could get all 3 intercooler logs together and see how they compare (forge, laguna and ths)
get some 4th gear logs done properly first then (couple of runs)
in winter and summer - then compare
price vs intake temps (winter and summer) vs pressure loss vs flow rate vs looks :)
their are also alot more coolers out their to compare to that no one has mentioned yet.....
