time line of the last 10 months on my fr
gazjones
in this pic you can see the valve like the n249. can you see the black and red hose going to it, remove the black one and replace it with another one going to the none return valve or connect the one from the back of the non return vave to this new hose with a straight connector
hope that makes sense
gazjones
this shows where the pipe goes after the non return valve from two angles
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
on the pic you sent i have numbered the ?? i have sorry to be a right pain but i just cant get mty finger on the arrangement
1. the pipe circle with number 1 where is this going off to??
2. the arrows pointing in the direction of the pipe here is this the pipe that plugs into the r.v?
3.where 3 is labeled is the black pipes that are dotted ids this section completly unplugged now??? or where does the corner piece to the right go too??
4. number four what and where is this going
once again sorry for being a propper pain!
EDIT: relised no4 is a connector wire!
gazjones
1 forget that just left it there so i can change it back usually plugged into other side of valve
2 long pipe along the back is normal dont need to touch that
3 the two ends of this are unplugged two middle connections stll attached but not doing anhything as its bypassed
4 is an electrical wire forget that leave it alone
gazjones
yes thats it but no need to remove anything makes it easy to change back just unplug what needs swapping about
rashcupra
Oct 15, 2006
6,517
crawley
will do is easy enough when you know but look alot more complicated than it is because you had the spare pipes lying about cheers gaz thanks for the help will do it moz or something cheers :cheers:
reedbradshaw
Spireite till i die
Oct 6, 2006
199
chesterfield
my 3 month time line
got the ibiza, had loaaaaaads of plans wanted all lots of factory bits on it eg chrome gear surround etc etc but wait!
Chesterfield autoworld is foooooookin shite!
so still i have no mods :p ( cept xenon look bulbs which look ok n not to chavvy think audi :p )
gazjones
lol im only doing little bits each month but looks like they dont stock and cupra interior bits every bit ive orderd has been on back order
gazjones
got the tool kit out this evening and started installing my tip, took 4 hours in total with a break for food was pretty difficult to do on my own so dad heled when neeed. will post a guide up for the mk4 soon but got few pics just to show what its like
original one
gazjones
yep but not got any stock of them yet ive been on to then for months about getting one gonna log it on vag com to see difference not driven it yet in anger only to check if id missed something
rashcupra
Oct 15, 2006
6,517
crawley
how much are they?? wouldnt mind getting my name on the list to get1 what was the hardest bit about fitting it then?
