Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
You don't want a LSD mte you want a ATB (Automatic Torque Biased) Differential as it uses gearing rather then clutch plates, so pretty much last forever! There not quite as effective as a LSD but pretty much! Once you driven a FWD car with a ATB you wont want to drive a FWD car without one!cu51pra said:cheer lads i will def get the lsd then
YerMother said:You don't want a LSD mte you want a ATB (Automatic Torque Biased) Differential as it uses gearing rather then clutch plates, so pretty much last forever! There not quite as effective as a LSD but pretty much! Once you driven a FWD car with a ATB you wont want to drive a FWD car without one!
RobDon said:I've done trackdays at Knockhill before and after having the Quaife ATB diff fitted - much, much more grip and speed through the bends with the diff.
The diff for the 6-speed Leon is: VW 02M121D 2WD
You'll need a bolt kit too, VW sell them or Jabba will get it for you.
