to diff or not to diff thats is the question
cu51pra
black ibiza cupra
Mar 15, 2005
1,111
harlow in essex
ive decided to get the jabba ihi kit done on my car now ive been quoted a great deal including the diff now the question is do i get one or not? is it worth the money and will it make a deference? any help with me making my mind up would be great:D
Songman
232
Ayrshire
Buy the diff - it does help - honest :)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
not that different in off the line straight line starts.. Just get to leave some No 11's on the road LOL
Corners is where it comes into its own.. out of roundabouts etc, it will put the power down and not spin up the inside wheel madly.
Once you have had a high power fwd car with a diff, you wont want to ever be without one.
Darth Tater
191
Kent
I'm getting a Quaife fitted in a couple of weeks
Will post up results in due course for anyone else that's considering the same
YerMother
comes and goes
Sep 22, 2004
1,461
East Midlands Drives: Scirocco GT
cu51pra said:
cheer lads i will def get the lsd then
You don't want a LSD mte you want a ATB (Automatic Torque Biased) Differential as it uses gearing rather then clutch plates, so pretty much last forever! There not quite as effective as a LSD but pretty much! Once you driven a FWD car with a ATB you wont want to drive a FWD car without one!
Darth Tater
191
Kent
Right...
Having just had a check on Quaife's site it appears it will most likely be an ATB diff although there doesn't appear to be a speciifc listing for a Leon, only Ibiza's :shrug:
It'll be whatever BBT's supply as they'll be fitting it, not me :whistle:
As long as it has the desired effect of allowing me to zoom round a few track days I'm not too fussed if it's ATB or LSD :funk:
RobDon
Pro Detailer
I've done trackdays at Knockhill before and after having the Quaife ATB diff fitted - much, much more grip and speed through the bends with the diff.
The diff for the 6-speed Leon is: VW 02M121D 2WD
You'll need a bolt kit too, VW sell them or Jabba will get it for you.
ColinT
Doing my first K'hill with my Quaife this Fri. Any advice on how I should drive? Same as before but just putting the power down earlier on exiting corners?
YerMother
comes and goes
Sep 22, 2004
1,461
Just get used to what the diff does first, you wont find that you need to change your driving style really, you'll just find that you don't have to be feathering the throttle all the time to stop the inside wheel spinning up!
Yumann
1,638
Glasgow
Just slap the throttle just before mid corner and hold wheel with both hand and let it rip out the corner.
The diff doesn't really do much in straight lines nor on very tight corners. Best on fast sweepers.
