Towbar install
rdhma
50
Limerick, Ireland
Hello, longtime Ibiza FR owner here, currently looking at a Leon FR TDI 184.
I'm planning for a towball mount bike carrier.
Has anyone fitted a towbar to a Leon Mk3, any issues with it?
There's a towbar wiring pre-install option, but not sure it's worth it if an installer wires it anyway.
sweetfr
Misty
Nov 24, 2007
159
24
Co Durham
I have a towbar fitted to my 184. I wanted a detachable so that when the towbar is not in use it does not spoil the back of the car.
After a lot of research I decided to go for the genuine seat towbar and cover. Got towbar fitted by a local towbar installer who I had used before. No need to use Seat genuine wiring. Opted for 13 pin socket and used 13 to 2 x 7 adapter lead. A couple of pics. One with towbar hook in and one with cover on.
Hope this helps.
phileddy
7
The detachable tow bar in the picture, how much is this from seat and what was the damage to have it fitted and the electrics? Looking at having this fitted to my fr
sweetfr
Misty
Nov 24, 2007
159
24
Co Durham
Hi Phileddy welcome to the forum
Here are the costs,
Towbar £186
Cover. £ 60
Fitting & wiring up. £165
Paint cover. £ 25
Make sure you get the correct cover for the FR as it is different to the S/SE because of the shape of the bumper.
Doug_m
73
NE Scotland
Hi,
Im looking at fitting a detachable towbar to my SC, how does it work with the lower bumper?
Do you buy a new piece with the detachable cover?
Thanks.
sweetfr
Misty
Nov 24, 2007
159
24
Co Durham
Hi,
there is no new piece of bumper to be bought just the cover. The rear bumper has to be removed for the towbar to be fitted and while it is off a hole is cut into it using the template that is supplied with the towbar.
Doug_m
73
NE Scotland
Hi,
Ok thanks.
So how good quality is the cover for fitment etc?
Wont fall off kinda thing.
Guess you bought all from the seat dealer? Installed aswell?
Cheers.
tjdixon
64
Suffolk
Hi,
Im just about to have a Tow Bar fitted to my FR, does anyone know the part number for the cover plate?
Is it only available from SEAT or does anyone know of another supplier?
I'm a little worried about having my bumper cut but I hope it will all be fine, they are professionals after all....
Instead of painting, I was thinking of Matt Blacking the under side of the bumper, following the lines of the already Matt Black number plate surround, if that makes sense, would this look naff? I was going to do it with sign writting vinyl as opposed to painting...
or should I just paint the cover to match for the sake of a few quid?
Also what bike carriers are you guys using?
rdhma
50
Limerick, Ireland
The cover is 5F0.803.595.A
I use an Atera Strada DL3 bike carrier, which I found to be the best trade off between weight, convenience and price.
tjdixon
64
Suffolk
Thanks - I had the bar installed yesterday, they cut a lot less bumper away than shown above, at some angles you can't see it so I am tempted not to bother with the cover (although the Seat one will not fit now)
I did a bit of research on the racks and opted for a Thule 9502, put it together last night and it looks ok - the real test will be when I try it out at the weekend.
dids
209
Stockport
Hello to tjdixon, do you have any pictures of your towbar and which make did you go for and swan neck or detachable ?
Conal
154
8
I have a detachable Witter fitted to my ST FR, no cover needed as the bumper cut is totally underneath so not visible at all when you are standing up. Have had problems with the factory pre wired electrics but that is another story!
Conal
dids
209
Stockport
I was thinking of going for a Westfalia swan neck type but I don't want a hole that's why I thought I go for that,now the guy who fitting it says that it may need a cover,great !
Muddybum
62
Hi guys,
I have bitten the bullet after quite a bit of research and ordered a Westfalia detachable bar with the full end to end wiring kit to a 13 pin end. This includes the split charging also, something not included on the manufacturer wiring as standard!
I am hoping to post up a photo guide to fitment once it all arrives, hopefully my privileges will permit on the forum.
Incidentally I use a Pendle bike rack and it is superb!
Simon
Muddybum
62
Conal I was going to message you regarding those photos but I can't respond to PMs yet. :(
Simon
dids
209
Stockport
Hello Simon can I ask how much the full kit is and where you have ordered it if you don't mind and are you fitting it yourself ?
