Hey everybody, new guy here!
Iv got a sedan Exeo 2.0 tdi cr 2010 with a 150k exactly on the clock.
The problem is the gearstick and gear change is very stiff in the mornings if its cold, i left my car outside for 2 days ( -3 to 6C) First the gearstick didnt move at all, had to use some force to get it moving, then it was really hard to change the gears. Once i succesfully changed every gear it was smooth and ok. I very much doubt the car has never had a transmission oil change, and the winter in Finland can be very rough for cars. I didnt find any mention in the manual when to change transmission oils. Could changing the oils help me? I dont recall it being THAT stiff last year in not so low temperatures.
Also 1 more question, the 3rd gear is bit "loose" i mean if i put 3rd gear in and put cruise on, the gearstick moves like 1-2cm if i try gently, other gears dont do that, is it normal or something to worry about?
Thanks alot, sorry if my english sucks
