Jan 8, 2008
528
Portsmouth
Hi all!
Wierd problem here, every so often my car goes into limp mode under hard boost but a switch off and restart always cures it.
Drove to work this morning and the car was fine, just sluggish, drove a few min ago and was as if I started the engine and was already in limp mode!? Switch off and on the engine 2 times and the turbo came back into action!!
Any ideas???
You need to take logs so we can see whats happening. Take one of block 4, 8 and 11.
Have you done a vagcom?
Ok Got the Log done, ran a full fault scan first ...
VCDS Version: Release 805.4
Data version: 20090602
Tuesday,25,May,2010,02:44:53:62635
Chassis Type: 6K - Seat Ibiza/Cordoba
Scan: 01 02 03 08 15 17 25 45 56
Mileage: 144170km/89583miles
Address 01: Engine Labels: None
Part No: 038 906 018 FB
Component: 1,9l R4 EDC 0000SG 2170
Coding: 00005
Shop #: WSC 06402
2 Faults Found:
17849 - EGR Valve (N18): Open Circuit or Short to Ground
P1441 - 35-10 - - - Intermittent
17958 - Charge Pressure: Control Deviation
P1550 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 11111
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
16-10 - Signal Outside Specifications - Intermittent
Address 08: Auto HVAC Labels: 6K0-959-291.lbl
Part No: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
No fault code found.
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: N AIRBAG VW3 SG 0002
Coding: 00078
Shop #: WSC 06402
Address 17: Instruments Labels: 6K0-920-xxx-17.lbl
Part No: 6K0 920 901 F
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00442
Shop #: WSC 00000
Part No: IMMO
Component: IDENTNR: SEZ7Z0A1350268
IMMO-IDENTNR: SEZ7Z0A1350268
Address 45: Inter. Monitor Labels: Redir Fail!
Part No: 6N0 951 171 C
Component: Innenraumueberw. 0003
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
3 Faults Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
00853 - Loudspeaker(s); Rear
00856 - Radio Antenna
End ---------------------------------------------------------------------
Cleared all the codes exept the ABS one as i will replace the sensor before i clear!
The EGR code came straight back up but this is because i have deleted the N18 and rerouted pipework, the code coming up wont cause any issues will it!!??
This is a log of groups 4, 8 & 11, look good!??
Group A: '004
RPM Ign. Timing Ign. Timing Duty Cycle
TIME
STAMP /min °BTDC °BTDC %
0.36 903 0.9 2.2 2.8
1.5 903 0.9 2.2 2.8
2.64 903 0.9 2.2 2.8
3.72 987 1.3 2.2 2.8
4.82 1218 1.3 1.5 2.8
5.94 1218 1.3 2 2.8
7.06 1344 1.3 2.6 2.8
8.14 1470 1.3 2.4 2.8
9.28 2142 0 0.4 2.8
10.38 2541 -0.9 -0.7 2.8
11.5 1638 0.2 2 2.8
12.6 1848 -0.2 1.3 2.8
13.72 2058 0 0.4 2.8
14.8 2331 0.4 0.2 23.9
15.92 2562 0 -0.9 26.3
17.04 1638 0 2 2.8
18.11 1680 0 2 2.8
19.19 1701 0 2 2.8
20.28 1743 -0.2 1.8 2.8
21.42 1785 -0.4 1.5 2.8
22.53 1785 -0.4 1.3 2.8
23.63 1806 -0.7 1.3 2.8
24.74 1848 -0.9 1.3 2.8
25.85 1827 -0.7 1.3 2.8
26.93 1848 -0.7 1.3 2.8
28.04 1848 -0.9 1.5 2.8
29.17 1890 -0.7 0.9 2.8
30.27 1932 -0.9 0.7 2.8
31.35 1953 -1.1 0.9 2.8
32.48 1974 -1.3 0.9 2.8
33.59 1890 -0.7 0 17.1
34.67 1785 0 0 16.7
35.77 1722 -0.2 1.5 2.8
36.91 1659 0 0 16.7
38.01 1554 0 0 16.7
39.09 1008 1.1 2 2.8
40.2 2163 -1.8 0 2.8
41.33 2100 -1.5 0.4 2.8
42.41 2100 -1.5 0.4 2.8
43.49 2142 -0.2 0 2.8
44.61 2289 0 0 23.9
45.75 2541 0.2 -0.4 28.3
46.85 2772 0.7 0 47
47.96 1806 -0.7 1.5 2.8
49.11 1785 -0.2 1.5 2.8
50.21 1743 0 0 16.7
51.29 1701 0 1.8 2.8
52.41 1617 0.2 2 2.8
53.48 1512 0 0 16.7
54.59 1470 1.1 2.4 2.8
55.68 1470 1.1 2.4 2.8
56.8 1491 1.1 2.2 2.8
57.88 1512 1.1 2 2.8
58.97 1533 0.9 2 2.8
60.07 1575 0.7 2.2 2.8
61.2 1596 0.4 2.2 2.8
62.28 1596 0.4 2 2.8
63.41 1533 0 0 16.7
64.55 1491 1.1 2.2 2.8
65.65 1533 1.1 2.2 2.8
66.74 1491 0 0 16.7
67.85 1386 0 0 17.9
68.96 1050 0.9 1.8 10
70.06 924 1.1 0 17.9
71.15 882 1.3 0 11.2
72.28 945 0.7 0 10.4
73.38 903 1.1 0 19.5
74.48 882 1.3 0 12.4
75.58 945 0.7 0 8.8
76.68 924 0.9 0 19.9
77.76 882 1.3 0 15.5
78.84 861 1.3 0 12
79.98 924 0.7 0 14.3
81.1 861 1.3 0 19.5
82.22 903 0.9 2.2 2.8
83.32 882 1.1 2.2 2.8
84.42 1365 1.1 2.6 2.8
85.52 1344 0.9 2.6 2.8
86.62 1281 1.1 2.2 2.8
87.74 1281 0.9 2.4 2.8
88.86 1512 1.3 2.2 2.8
89.95 1491 0 0 16.7
91.09 945 0.9 2.2 2.8
92.22 924 0.9 2.4 2.8
93.3 903 1.1 2.2 2.8
94.37 903 0.9 2.4 2.8
95.52 1386 1.3 2.4 2.8
96.61 1197 1.3 2.2 2.8
97.73 1848 0 1.3 2.8
98.82 2646 -0.7 -1.1 37.5
99.93 1722 0 1.8 2.8
101.04 2142 0.4 0.4 10.4
102.14 2520 1.1 0.4 46.2
103.26 2436 -1.1 -0.4 14.3
104.37 1785 0 1.5 2.8
105.49 1890 0 1.1 2.8
106.6 1953 -1.3 0.9 2.8
107.74 1953 -1.1 0.9 2.8
108.83 1932 -1.1 0.9 2.8
109.93 1911 -0.9 0.9 2.8
111.06 1869 -0.7 0 15.9
112.15 1827 -0.4 0.9 2.8
113.23 1911 0 0.9 2.8
114.34 2016 0 0.7 2.8
115.47 2142 0 0 19.1
116.57 2226 -1.3 0 2.8
117.67 2247 -1.5 0.2 2.8
118.79 2205 -1.8 0.2 2.8
119.91 2142 -1.8 0 2.8
120.99 2037 -1.5 0 17.1
122.1 2016 -1.5 0.4 2.8
123.23 2016 -1.5 0.4 2.8
124.31 2016 -1.5 0.7 2.8
125.39 2016 -1.3 0.2 2.8
126.53 2058 -1.1 0.2 2.8
127.65 2079 -1.1 0.2 2.8
128.73 2100 -1.8 0.4 2.8
129.85 2121 -1.8 0.2 2.8
130.97 2142 -1.8 0.4 2.8
132.05 2142 -1.8 0.7 2.8
133.12 2142 -1.8 0.7 2.8
134.24 2184 -0.9 0.2 2.8
135.36 2205 -0.9 0 2.8
136.45 2226 -0.9 0.2 2.8
137.55 2394 3.7 1.8 69.7
138.65 2709 6.6 6.6 75.7
139.78 3003 6.2 7 60.2
140.88 2982 -0.4 2.4 2.8
142.01 2457 9 8.1 76.5
143.15 2688 9.7 9.2 80.5
144.24 2877 10.8 12.3 85.7
145.36 2352 9 2.6 96.4
146.49 2289 -1.5 0.9 4.8
147.58 2205 -1.8 0 16.3
148.66 2058 -1.5 0 17.1
149.77 1890 -0.7 0 17.1
150.84 1764 0 0 16.7
151.92 1743 -0.4 1.3 2.8
153.02 1743 -0.2 1.3 2.8
154.11 1764 0 1.5 2.8
155.24 1806 0 1.3 2.8
156.36 1869 0 1.3 2.8
157.49 1890 -0.7 0.7 2.8
158.58 1911 -0.9 0.4 2.8
159.66 1932 -1.1 0.4 2.8
160.76 1974 -0.4 0.2 2.8
161.9 1995 -0.4 0.7 2.8
162.98 2037 -0.2 0.2 2.8
164.06 2058 0 0.7 2.8
165.17 2100 0 0.7 4.8
166.26 2121 0 0.4 9.2
167.34 2142 0 0.2 10.8
168.44 2163 0.2 0.4 14.7
169.54 2184 0.7 0 29.9
170.66 2226 0.9 0.2 37.1
171.76 2268 1.3 0.4 54.6
172.84 2310 1.3 1.1 53
173.96 2331 0.2 1.3 39.8
175.06 2331 -1.1 0 27.5
176.18 2289 -1.8 0 2.8
177.26 2247 -2 0 2.8
178.39 2226 -1.8 0.4 2.8
179.49 2184 -1.1 0 3.6
180.6 2184 -1.1 0 2.8
181.72 2163 -0.7 0 2.8
182.83 2142 -0.4 0 2.8
183.91 2142 0 0.2 2.8
185.02 2142 0 0 3.6
186.11 2163 0.2 0.2 7.2
187.19 2184 0.2 0.4 9.6
188.27 2184 0 0.2 10.8
189.41 2184 -0.4 0 4
190.51 2184 -0.4 0.2 2.8
191.59 2184 0.2 0.7 5.2
192.7 2184 0.2 0 6.4
193.82 2184 0.7 0 14.3
194.91 2205 0.7 0 19.5
196.01 2226 0.7 0.2 26.7
197.13 2247 0.7 0.2 33.5
198.25 2289 3.3 2.6 60.6
199.33 2352 2 1.8 54.6
200.44 2331 -0.9 -0.4 29.1
201.55 2289 -1.8 0 2.8
202.65 2247 -2 0 2.8
203.73 2226 -1.8 0 15.9
204.83 2226 -1.5 0 2.8
205.93 2247 0.7 0 30.7
207.01 2310 0.9 0.2 41.4
208.11 2331 -1.1 0 20.7
209.23 2310 -1.8 0 2.8
210.35 2310 -1.5 0 4
211.44 2268 -1.5 0 2.8
212.56 2226 -1.8 0.2 2.8
213.67 2205 -1.8 0.2 2.8
214.78 2163 -1.8 0.2 2.8
215.87 2142 -0.4 0 2.8
216.99 2142 0.2 0.4 2.8
218.1 2163 0 0.2 2.8
219.18 2163 0 0.4 5.2
220.29 2142 -1.8 0.7 2.8
221.38 2121 -1.5 0 16.7
222.46 2058 -1.5 0 17.1
223.56 2037 -1.5 0 17.5
224.69 1974 -1.3 0 17.5
225.78 1995 0.7 0.7 2.8
226.9 2079 1.3 0.4 29.5
228.03 2142 1.1 0.2 25.5
229.14 2163 -0.4 0.2 6.4
230.24 2163 -1.3 0 2.8
231.34 2163 -1.8 0 2.8
232.48 2184 0.2 0.2 12
233.58 2226 1.3 0 49
234.66 2289 1.1 0.2 51.8
235.75 2310 0 0.2 41
236.86 2331 0.4 0 43.4
237.94 2352 0.4 0.4 44.2
239.02 2415 2.4 2.9 58.6
240.17 2436 -1.1 0 23.1
241.26 2394 -1.3 0 16.3
242.33 2310 -1.8 0 15.9
243.44 2205 -1.8 0 15.9
244.58 2142 -1.8 0 16.7
245.68 2142 0.4 0.2 22.3
246.8 2205 0.9 -0.2 39.8
247.92 2268 1.8 2 56.6
249.02 2247 -2 0 15.9
250.14 2205 -1.8 0.2 2.8
251.22 2184 -0.2 0 16.3
252.34 2205 0 0.4 17.5
253.43 2226 0 0 25.5
254.53 2205 -1.8 0 2.8
255.66 2226 -1.5 0 2.8
256.8 2205 0.7 0 28.3
257.88 2247 0 0 26.7
259 2247 0.4 0.2 35.9
260.11 2268 0.4 0.2 37.1
261.22 2289 1.5 0.2 56.6
262.29 2352 5.3 5.7 64.5
263.44 2436 4.6 5.3 64.1
264.55 2499 4.8 4.4 62.6
265.63 2499 -0.9 0 19.9
266.74 2457 -1.1 0 16.7
267.87 2394 -1.3 0 16.3
268.95 2331 -1.5 0 16.3
270.03 2310 0.4 0.2 35.5
271.16 2352 1.1 0 52.2
272.27 2373 0.4 0.7 45.4
273.35 2373 -1.5 0 15.9
274.43 2331 -1.5 0 6
275.55 2352 0.4 0.2 32.7
276.63 2373 0.9 0 43
277.75 2415 1.5 1.3 54.6
278.87 2436 -0.9 0.2 34.7
280.01 2415 -1.3 -0.2 13.5
281.09 2415 0 -0.7 27.9
282.17 2415 0.9 0 43.4
283.29 2457 1.3 0.9 54.2
284.41 2478 0.4 0.2 43.8
285.49 2499 1.5 1.8 56.6
286.6 2478 -1.1 -0.4 22.3
287.7 2457 -1.1 -0.7 23.9
288.81 2436 0.7 0 44.6
289.89 2478 1.1 0.9 50.2
291.02 2520 1.1 1.1 50.6
292.13 2520 0 0 40.2
293.23 2520 0.4 0.4 45
294.31 2520 0 -0.2 39.4
295.43 2520 1.3 0.2 58.2
296.5 2562 1.3 2 49.4
297.6 2541 -0.4 -0.7 39
298.73 2499 -0.9 -0.4 26.7
299.83 2478 0.2 -0.7 41
300.92 2478 0.4 0.2 45
302.05 2478 0 -0.2 37.5
303.19 2457 -0.2 -0.2 39.4
304.28 2436 0 0 39.8
305.4 2415 0.7 0.2 51.4
306.51 2415 1.1 1.1 48.6
307.62 2436 1.1 1.3 47.4
308.7 2436 0.4 0.4 46.6
309.81 2436 0.7 0.4 45
310.9 2436 0.9 0.7 49.4
312 2436 0.9 1.1 46.2
313.1 2436 0.9 1.1 45
314.22 2436 0.7 0.9 47.8
315.3 2415 -1.1 0 27.5
316.38 2415 0.9 0.4 49.8
317.51 2415 0.9 0.9 47.8
318.64 2415 1.5 0.9 58.6
319.76 2436 0.9 1.8 53.8
320.84 2436 0.4 0.4 43.8
321.96 2415 0 0 43.4
323.04 2394 0 -0.2 42.2
324.16 2373 0.4 0.4 48.6
325.25 2394 1.5 1.1 58.6
326.36 2415 1.1 1.8 48.2
327.43 2415 0.4 1.1 46.6
328.52 2415 0.7 0.4 49.4
329.62 2415 0.7 0.9 45
330.7 2415 0.2 0 45.8
331.78 2415 0.7 1.3 47.4
332.88 2415 0.7 1.1 49
334.02 2415 0.4 0.2 44.6
335.1 2394 0.4 0.2 44.2
336.21 2394 0.7 0.4 48.2
337.3 2394 0.7 0.7 46.2
338.42 2415 1.1 0.9 52.2
339.5 2415 0.4 0.7 43.4
340.57 2394 0.7 0.2 47
341.7 2394 0.7 0.7 46.2
342.8 2394 0.7 0.7 43
343.91 2394 0.2 0.2 44.2
345.02 2373 0.2 0 45.4
346.09 2373 0.4 0.2 47
347.17 2373 0.7 0.9 50.6
348.27 2352 0 0.2 40.6
349.39 2331 0.7 0.2 44.2
350.51 2352 1.5 1.8 55.8
351.61 2394 1.5 1.8 57
352.72 2415 0.4 1.1 39.8
353.83 2415 0.4 0.4 45.8
354.91 2394 0.4 0.7 45
356.04 2394 0.4 0.4 45
357.17 2394 0.4 0.4 44.2
358.25 2394 0.9 0.7 50.2
359.33 2415 0.9 0.9 49
360.45 2415 0.7 1.1 44.2
361.57 2415 0.7 1.1 49.8
362.65 2415 0.7 0.4 47.8
363.75 2415 0.4 0.4 44.2
364.85 2415 0.4 0.2 43.4
365.97 2415 0.4 0.4 42.6
367.05 2394 0.2 0.2 45.4
368.14 2373 -1.3 -0.4 19.9
369.27 2352 -0.9 -0.2 15.5
370.37 2331 -0.4 0 12.8
371.46 2310 -0.4 0 13.1
Now im not quite sure what all this info means but the 1st Inj quantity (my guess is its an injector?) is quite worrying!! Very far out figures!!
Group B: '008
RPM Inj. Quantity Inj. Quantity Inj. Quantity
TIME
STAMP /min mg/str mg/str mg/str
0.75 903 0 42 24
1.89 903 0 42 24.2
3 903 0 42 24.2
4.08 1008 3.8 43.4 25.6
5.2 1239 5.4 49.4 27.4
6.32 1134 0 46.6 27
7.42 1344 10.4 51 30.4
8.52 1680 13.4 51 31.8
9.66 2394 13.2 51 39.6
10.75 2331 3.4 51 29.6
11.86 1701 12.8 51 31.8
12.98 1911 12.2 51 33
14.08 2121 12 51 36
15.16 2415 15.2 51 41.8
16.28 2436 0 51 29.6
17.4 1659 6.6 51 28
18.47 1680 8.6 51 29.6
19.55 1722 11.6 51 32.2
20.66 1743 8.6 51 32.6
21.79 1764 6.4 51 30.6
22.9 1785 5.8 51 29.2
24 1827 5.6 51 29.4
25.11 1827 5.6 51 29
26.21 1827 5.8 51 29.6
27.29 1848 5 51 28.8
28.42 1869 8.8 51 30.2
29.55 1911 9.2 51 32.2
30.63 1932 9 51 33
31.73 1953 6.8 51 31.4
32.85 1932 1.4 51 28.8
33.95 1848 0 51 25.2
35.03 1743 1 51 25.2
36.16 1701 0.2 51 26.2
37.29 1617 0 51 24.6
38.37 1491 0 51 24.6
39.47 1071 4.2 44.6 25.4
40.57 2100 4 51 27.4
41.69 2121 4.8 51 30.6
42.77 2100 5.2 51 31.6
43.88 2163 11.4 51 36.6
44.99 2373 13.2 51 35
46.11 2625 12.8 51 37.6
47.2 2730 0 51 29.4
48.35 1848 6.2 51 27.4
49.49 1806 0 51 25.4
50.57 1722 2.8 51 26.2
51.67 1680 1.6 51 25.6
52.77 1596 0.2 51 25.4
53.85 1533 3.6 51 25.8
54.95 1470 3.8 51 26.4
56.06 1491 5.6 51 27.2
57.16 1512 6 51 28
58.24 1533 7 51 27.8
59.33 1554 7.2 51 28.6
60.45 1575 7.2 51 28.2
61.57 1596 4.8 51 27.8
62.64 1596 3.6 51 27.4
63.79 1512 2.6 51 24.2
64.92 1512 9 51 27.6
66.03 1533 6.6 51 28.8
67.1 1470 0 51 25.4
68.22 1344 0 51 26.2
69.32 966 0 42.8 25.2
70.42 945 0 42.2 24.2
71.53 903 0 42.2 24
72.64 882 0 42 24.2
73.76 903 0 42.2 23.8
74.84 903 0 42 23.8
75.96 903 0 41.8 24.4
77.04 924 0 42 24.2
78.12 924 0 42.4 23.8
79.22 903 0 42 24.2
80.36 945 0 42.4 24.2
81.48 903 0 42 24.4
82.58 924 0 42.2 24
83.7 882 0 42 24
84.78 1407 2.8 51 27.6
85.88 1323 2.4 51 28.2
87.01 1281 2.4 50.2 27.6
88.12 1260 1.8 50 27.4
89.23 1827 10.2 51 30.2
90.32 1155 0 47.4 27.8
91.46 987 0 42.8 24.6
92.57 903 0 42.2 24.2
93.65 903 0 42.2 24.4
94.76 903 0 42 24.4
95.9 1344 9 51 29.2
96.98 1197 13.2 48.2 29.2
98.09 2163 15.6 51 39.8
99.18 2394 0 51 30.4
100.31 1848 18 51 39
101.41 2268 18 51 44.4
102.5 2625 17 51 46
103.63 2037 10.8 51 29.6
104.73 1827 14 51 35.2
105.85 1932 12.4 51 34
106.98 1953 4.4 51 27.6
108.11 1953 4 51 26
109.19 1932 2.4 51 25.6
110.3 1890 2.6 51 25.6
111.43 1848 0.8 51 25.4
112.51 1911 6.8 51 25.8
113.59 1932 12.6 51 33.2
114.72 2058 14.4 51 37.8
115.85 2184 11.4 51 32.2
116.93 2226 7.8 51 31.2
118.04 2247 4.6 51 29.8
119.17 2184 0.2 51 25.6
120.27 2121 0.8 51 26.2
121.37 2058 3.8 51 27.4
122.48 2016 4 51 28.8
123.59 1995 5.2 51 29.8
124.67 2016 7 51 30.4
125.77 2037 7.4 51 31.6
126.91 2058 8.6 51 32.8
128.01 2079 6.8 51 33.2
129.13 2121 5.4 51 31.2
130.23 2121 5.6 51 31.2
131.33 2142 5.2 51 31
132.41 2142 5.4 51 31
133.49 2142 6.2 51 31.4
134.61 2184 10 51 36
135.73 2205 9.8 51 37.6
136.81 2247 13.6 51 38.4
137.91 2499 28.4 51 47.6
139.03 2814 27.4 51 46.4
140.15 3108 26.2 51 46
141.26 2625 33.4 51 41
142.39 2541 34.8 51 47.4
143.52 2772 33.4 51 46.6
144.6 2919 21.4 51 46.2
145.73 2289 37.2 51 46.8
146.86 2247 0 51 24.4
147.94 2163 0 51 23.6
149.02 1995 0 51 25
150.13 1827 0 51 25.2
151.2 1785 4.2 51 26.6
152.28 1743 11.6 51 31.6
153.39 1743 12.4 51 35.2
154.48 1764 16 51 36.8
155.6 1806 16.6 51 34.4
156.74 1869 14.6 51 32.8
157.86 1890 7.4 51 29
158.94 1911 7.6 51 28.6
160.02 1953 7.2 51 28.6
161.12 1974 10.8 51 30.8
162.26 2016 11 51 32.8
163.34 2037 12.2 51 34
164.42 2079 11.8 51 35.6
165.53 2100 14.4 51 35.2
166.62 2142 14.4 51 33.2
167.72 2142 14.6 51 31.8
168.8 2184 15.8 51 35.8
169.92 2205 19.8 51 42.8
171.01 2226 19.4 51 43.4
172.12 2289 21.6 51 45.6
173.21 2331 21.4 51 45.8
174.33 2331 8.6 51 35
175.43 2310 5.6 51 31.4
176.53 2268 0 51 25.8
177.64 2226 3.4 51 29
178.75 2205 5.2 51 32.8
179.86 2184 8.8 51 36.6
180.98 2184 9.4 51 37.8
182.09 2163 10.8 51 39
183.19 2142 10.8 51 39.4
184.28 2142 12.6 51 33.2
185.4 2142 15.8 51 30.8
186.47 2163 15.6 51 33.8
187.55 2184 14.6 51 32.2
188.66 2184 13 51 29.8
189.79 2184 10.6 51 32
190.87 2184 11.2 51 34.4
191.95 2163 15.4 51 37.8
193.06 2163 15.4 51 35
194.19 2184 18.6 51 40.4
195.29 2205 18.8 51 40.8
196.38 2226 18.6 51 40.8
197.51 2247 24.6 51 43.2
198.61 2310 26.2 51 46.6
199.69 2352 19 51 46.4
200.81 2310 6.2 51 29.6
201.93 2289 4.4 51 31.2
203.01 2226 0 51 28.8
204.09 2205 0 51 25.8
205.21 2205 14.8 51 38.2
206.29 2268 19.2 51 39.2
207.39 2331 17.2 51 40
208.47 2331 7.2 51 32.4
209.61 2310 5.2 51 32
210.73 2289 7.2 51 36
211.81 2247 4 51 33.2
212.93 2205 3.6 51 29.8
214.04 2163 4.4 51 30.2
215.14 2142 9 51 33.6
216.25 2142 10.8 51 36.6
217.36 2142 14.4 51 32.8
218.47 2163 14 51 28.4
219.54 2163 13 51 30.6
220.67 2163 0 51 25
221.74 2100 0 51 25.4
222.82 2058 0 51 25.2
223.95 2016 0 51 25.2
225.06 1995 3.2 51 25
226.15 2016 23.4 51 46.4
227.28 2100 23.2 51 43.2
228.41 2163 15.2 51 37.4
229.5 2163 11 51 34.6
230.62 2184 4.8 51 30.6
231.73 2163 9.2 51 30.8
232.84 2205 16 51 35.2
233.94 2247 21 51 43.8
235.02 2289 20.6 51 44
236.12 2310 13.2 51 32
237.22 2331 15.2 51 34.4
238.3 2373 24.8 51 45.2
239.41 2436 24.2 51 46.8
240.54 2436 0 51 29.6
241.62 2373 0 51 28.4
242.7 2289 0 51 26.4
243.82 2184 0 51 26
244.96 2142 5.6 51 27.4
246.04 2163 20.4 51 40
247.18 2226 23.6 51 38.4
248.28 2289 14.6 51 38.2
249.38 2226 0 51 26.2
250.5 2184 8.6 51 34.8
251.6 2184 11 51 39.2
252.7 2205 18.2 51 34.8
253.79 2247 11.8 51 27.2
254.9 2205 0 51 25.4
256.04 2184 15.6 51 40
257.16 2226 19.4 51 38.8
258.24 2247 13.8 51 29.2
259.36 2268 16.6 51 33.2
260.49 2268 16.4 51 33.8
261.57 2310 28 51 45.8
262.68 2394 27.6 51 47.2
263.82 2457 27.2 51 47.4
264.91 2499 23 51 47.2
266 2478 0 51 29.4
267.12 2436 0 51 28.4
268.23 2373 0 51 28.2
269.31 2310 0 51 27.2
270.39 2331 16.2 51 36.4
271.54 2352 19.8 51 39
272.63 2394 9.4 51 30.2
273.71 2331 2.8 51 31
274.81 2331 12 51 38.6
275.91 2352 17.4 51 37.2
277.01 2394 21.8 51 41.2
278.11 2436 21.4 51 44
279.25 2436 3.6 51 32.2
280.37 2436 5 51 35
281.45 2415 14 51 31.4
282.54 2436 17 51 39.2
283.67 2478 19.4 51 42.8
284.77 2499 18.8 51 32.6
285.85 2499 12.6 51 36.2
286.97 2478 3.8 51 32.6
288.07 2436 4.4 51 36
289.17 2457 18.4 51 42
290.27 2478 18.4 51 41.2
291.39 2520 16.8 51 41.8
292.51 2520 11.8 51 29.4
293.58 2520 14 51 31.6
294.69 2520 10.2 51 37
295.78 2541 18.6 51 44.8
296.86 2562 10.4 51 41.2
297.97 2520 3.8 51 33.4
299.1 2499 5.2 51 35.8
300.18 2478 14.8 51 35.4
301.28 2478 14.8 51 32.4
302.43 2457 10.6 51 30.2
303.56 2436 11 51 30.2
304.64 2415 11.4 51 31.4
305.77 2415 16.8 51 39
306.88 2415 17.8 51 40.6
307.98 2436 17.8 51 39.4
309.06 2436 15.2 51 31.6
310.17 2436 16.2 51 33.2
311.26 2436 17.6 51 37.6
312.38 2436 17.4 51 38.2
313.47 2436 16.6 51 36
314.58 2436 13 51 32.4
315.66 2394 7.4 51 31.8
316.76 2415 19.2 51 41.8
317.89 2415 10.2 51 37.8
319.02 2436 20.6 51 46
320.12 2436 16.6 51 39.6
321.21 2436 14.6 51 30.2
322.32 2415 11.6 51 28
323.42 2394 11.6 51 28.6
324.52 2373 18.8 51 39.4
325.62 2394 20.6 51 43.2
326.72 2415 18.4 51 38.6
327.8 2415 14.2 51 30
328.9 2415 16.8 51 32
329.98 2415 12 51 29.4
331.05 2415 16.6 51 29
332.14 2415 16.6 51 31.8
333.27 2415 15.8 51 31.8
334.38 2415 14.6 51 29.6
335.47 2394 15.2 51 29.6
336.57 2394 16.6 51 31.6
337.68 2394 18.4 51 34.2
338.77 2394 16 51 38.2
339.85 2415 15.8 51 31
340.94 2394 16.6 51 31.8
342.07 2394 16.2 51 31.6
343.17 2394 16 51 31.8
344.27 2394 14.2 51 28.8
345.38 2373 14.4 51 28.4
346.45 2373 15.2 51 29.4
347.53 2373 17.6 51 32.6
348.63 2352 8 51 29
349.77 2352 21 51 44.6
350.87 2373 22 51 43
351.97 2394 21.4 51 42.4
353.09 2415 15.6 51 31.8
354.19 2415 15.6 51 30.2
355.3 2394 15.6 51 30
356.42 2394 15.8 51 30.2
357.53 2373 15.8 51 30.4
358.61 2394 17.6 51 34.6
359.69 2415 17.4 51 34.6
360.83 2415 16.8 51 33.8
361.93 2415 17 51 33.6
363.01 2415 14.6 51 32.2
364.11 2415 14.6 51 29.8
365.23 2415 14.6 51 29.2
366.33 2394 14.4 51 28.8
367.4 2394 6.2 51 28
368.52 2373 6.2 51 37
369.65 2352 9.4 51 39.6
370.72 2331 10.6 51 40.8
371.83 2331 16.2 51 37.8
Group C: '011
RPM Absolute Pres. Absolute Pres. Duty Cycle
TIME
STAMP /min mbar mbar %
0.01 903 999.6 1050.6 24.7
1.12 903 999.6 1050.6 24.7
2.26 903 999.6 1050.6 24.7
3.36 882 999.6 1050.6 24.7
4.44 966 999.6 1060.8 24.7
5.56 1239 1040.4 1111.8 24.7
6.7 1092 1020 1122 24.7
7.78 1281 1101.6 1224 27.9
8.9 1911 1203.6 1428 42.2
10.02 2604 1234.2 1468.8 66.1
11.12 1785 1142.4 1387.2 26.7
12.24 1785 1173 1356.6 29.1
13.36 1995 1183.2 1438.2 28.7
14.44 2226 1264.8 1581 57
15.53 2520 1275 1560.6 67.7
16.66 1953 1050.6 1264.8 28.7
17.76 1659 1091.4 1264.8 33.1
18.84 1680 1101.6 1305.6 33.9
19.91 1722 1152.6 1377 31.1
21.04 1764 1111.8 1377 33.9
22.17 1785 1081.2 1336.2 33.5
23.27 1806 1071 1295.4 34.3
24.36 1827 1071 1295.4 34.7
25.49 1827 1081.2 1305.6 34.7
26.57 1827 1081.2 1305.6 35.1
27.65 1848 1081.2 1295.4 34.3
28.79 1890 1132.2 1356.6 29.9
29.91 1911 1132.2 1407.6 29.5
30.99 1953 1122 1438.2 32.3
32.1 1953 1091.4 1397.4 36.3
33.23 1932 1050.6 1275 31.5
34.31 1806 1050.6 1173 31.5
35.39 1722 1050.6 1173 32.3
36.54 1680 1050.6 1193.4 32.3
37.65 1575 1050.6 1142.4 33.5
38.73 1134 1020 1111.8 24.7
39.83 1701 1050.6 1081.2 33.1
40.95 2121 1091.4 1305.6 32.3
42.05 2121 1091.4 1407.6 33.5
43.13 2100 1101.6 1428 34.7
44.24 2205 1183.2 1591.2 33.5
45.37 2478 1234.2 1366.8 55.8
46.49 2709 1234.2 1377 61
47.59 2331 1060.8 1285.2 25.5
48.73 1848 1081.2 1295.4 34.7
49.85 1764 1050.6 1203.6 31.5
50.93 1701 1050.6 1193.4 32.3
52.05 1638 1050.6 1193.4 32.7
53.12 1554 1050.6 1162.8 33.9
54.23 1470 1050.6 1152.6 32.7
55.31 1491 1050.6 1162.8 32.3
56.43 1491 1050.6 1183.2 31.9
57.53 1512 1060.8 1203.6 32.3
58.6 1533 1081.2 1224 32.7
59.71 1575 1081.2 1254.6 33.1
60.82 1596 1060.8 1254.6 32.7
61.92 1596 1050.6 1234.2 32.7
63.02 1554 1050.6 1193.4 33.1
64.17 1491 1050.6 1142.4 32.7
65.28 1533 1091.4 1224 34.3
66.38 1491 1050.6 1224 33.9
67.47 1428 1050.6 1132.2 33.1
68.6 1176 1030.2 1101.6 24.7
69.7 924 999.6 1071 24.7
70.78 903 999.6 1060.8 24.7
71.91 924 999.6 1060.8 24.7
73.02 882 999.6 1060.8 24.7
74.12 945 999.6 1060.8 24.7
75.21 924 999.6 1060.8 24.7
76.32 882 999.6 1060.8 24.7
77.4 882 999.6 1060.8 24.7
78.48 903 999.6 1060.8 24.7
79.6 924 999.6 1060.8 24.7
80.74 903 999.6 1060.8 24.7
81.86 882 999.6 1060.8 24.7
82.95 903 999.6 1050.6 24.7
84.06 987 999.6 1050.6 24.7
85.14 1365 1050.6 1142.4 30.7
86.26 1302 1050.6 1162.8 28.7
87.38 1281 1050.6 1152.6 28.7
88.48 1302 1050.6 1142.4 26.7
89.6 1932 1081.2 1366.8 33.9
90.7 987 999.6 1193.4 24.7
91.84 924 999.6 1091.4 24.7
92.94 903 999.6 1060.8 24.7
94.01 903 999.6 1050.6 24.7
95.14 1008 999.6 1050.6 24.7
96.26 1260 1081.2 1193.4 24.7
97.36 1512 1162.8 1264.8 35.5
98.46 2457 1264.8 1662.6 72.9
99.56 1869 1203.6 1366.8 38.3
100.67 1995 1295.4 1601.4 51.4
101.78 2394 1326 1734 76.1
102.88 2667 1111.8 1774.8 36.3
104.01 1932 1193.4 1428 41.8
105.11 1869 1193.4 1479 49.4
106.22 1953 1132.2 1417.8 30.3
107.36 1953 1071 1264.8 35.5
108.47 1953 1071 1224 34.7
109.56 1911 1060.8 1193.4 33.5
110.68 1869 1050.6 1183.2 31.9
111.79 1848 1050.6 1173 31.9
112.87 1869 1183.2 1244.4 27.9
113.95 1974 1183.2 1448.4 28.3
115.09 2100 1224 1581 55.8
116.21 2205 1132.2 1356.6 30.7
117.29 2226 1132.2 1377 29.1
118.41 2226 1071 1356.6 25.1
119.55 2142 1060.8 1264.8 28.7
120.63 2079 1050.6 1264.8 30.7
121.73 2037 1081.2 1305.6 35.5
122.85 2016 1081.2 1346.4 36.3
123.95 2016 1101.6 1366.8 36.7
125.03 2016 1111.8 1397.4 35.1
126.15 2037 1132.2 1417.8 33.5
127.27 2079 1132.2 1468.8 34.3
128.37 2100 1111.8 1468.8 34.3
129.49 2121 1091.4 1428 33.9
130.61 2142 1101.6 1417.8 32.7
131.69 2142 1091.4 1417.8 31.9
132.77 2142 1101.6 1417.8 31.5
133.87 2163 1142.4 1448.4 31.5
134.99 2184 1152.6 1570.8 31.1
136.09 2205 1152.6 1611.6 30.7
137.18 2310 1662.6 1611.6 47.4
138.29 2604 1764.6 2233.8 78.1
139.4 2919 1754.4 2499 94.4
140.52 3213 1621.8 2560.2 94.4
141.63 2373 1999.2 2142 57.8
142.77 2625 1999.2 2570.4 90.4
143.88 2814 1999.2 2570.4 94.4
144.97 2625 1071 1897.2 31.5
146.11 2268 1356.6 2376.6 85.3
147.22 2226 1050.6 1224 24.7
148.3 2121 1050.6 1162.8 28.3
149.39 1953 1050.6 1244.4 31.5
150.49 1806 1050.6 1234.2 31.5
151.56 1764 1081.2 1275 33.1
152.64 1743 1152.6 1417.8 30.3
153.75 1764 1162.8 1530 29.9
154.86 1785 1224 1509.6 49
155.98 1848 1224 1479 49
157.1 1890 1203.6 1407.6 49
158.22 1911 1111.8 1326 33.1
159.3 1932 1111.8 1305.6 33.1
160.38 1953 1111.8 1305.6 34.3
161.51 1995 1162.8 1387.2 29.1
162.62 2037 1162.8 1458.6 30.3
163.7 2058 1193.4 1509.6 30.7
164.78 2079 1213.8 1540.2 52.6
165.9 2121 1234.2 1479 52.2
166.98 2142 1213.8 1397.4 50.6
168.08 2163 1244.4 1397.4 51
169.17 2163 1377 1489.2 55
170.28 2226 1366.8 1703.4 74.1
171.38 2247 1356.6 1723.8 81.7
172.48 2289 1428 1856.4 89.3
173.58 2352 1397.4 1866.6 94.4
174.69 2331 1142.4 1438.2 31.5
175.82 2289 1091.4 1397.4 25.9
176.89 2268 1060.8 1326 24.7
178.02 2226 1081.2 1428 25.5
179.12 2205 1101.6 1499.4 28.7
180.21 2184 1142.4 1611.6 31.1
181.36 2163 1162.8 1662.6 32.3
182.45 2163 1162.8 1703.4 32.3
183.55 2142 1173 1703.4 32.3
184.64 2142 1203.6 1407.6 49.4
185.76 2163 1264.8 1336.2 43.8
186.83 2163 1264.8 1407.6 50.2
187.91 2184 1244.4 1377 51
189.04 2184 1193.4 1315.8 48.2
190.15 2184 1173 1407.6 32.3
191.23 2163 1193.4 1479 33.9
192.31 2184 1254.6 1530 57.4
193.44 2163 1285.2 1479 55
194.55 2205 1336.2 1601.4 64.1
195.65 2226 1336.2 1642.2 70.1
196.76 2247 1336.2 1652.4 74.1
197.89 2268 1672.8 1856.4 63.8
198.97 2331 1632 2080.8 86.1
200.06 2352 1183.2 1744.2 94.4
201.17 2289 1101.6 1377 25.5
202.29 2268 1091.4 1448.4 24.7
203.37 2226 1050.6 1366.8 24.7
204.45 2184 1071 1326 26.3
205.57 2226 1346.4 1734 66.1
206.65 2289 1346.4 1570.8 62.6
207.75 2331 1193.4 1479 63.4
208.85 2331 1101.6 1397.4 26.3
209.98 2310 1101.6 1458.6 25.9
211.09 2289 1122 1509.6 27.5
212.17 2247 1081.2 1458.6 24.7
213.31 2184 1081.2 1407.6 27.5
214.41 2163 1091.4 1397.4 29.9
215.51 2142 1142.4 1479 32.3
216.63 2142 1264.8 1632 59
217.72 2142 1234.2 1377 46.6
218.82 2163 1285.2 1326 43.8
219.91 2163 1193.4 1326 47.4
221.03 2142 1050.6 1254.6 28.3
222.1 2079 1050.6 1264.8 30.3
223.18 2037 1050.6 1254.6 31.5
224.31 1995 1050.6 1234.2 31.5
225.42 1974 1152.6 1285.2 30.3
226.52 2037 1489.2 1989 68.1
227.65 2121 1438.2 1693.2 59
228.78 2163 1152.6 1428 31.5
229.88 2184 1162.8 1468.8 31.9
230.98 2184 1091.4 1387.2 29.5
232.11 2184 1275 1509.6 49
233.2 2205 1468.8 1540.2 45.4
234.3 2268 1417.8 1713.6 68.1
235.38 2310 1224 1611.6 78.1
236.5 2331 1224 1346.4 59.8
237.58 2331 1264.8 1397.4 63.4
238.66 2394 1560.6 1805.4 68.1
239.79 2457 1397.4 1999.2 94.4
240.9 2415 1060.8 1407.6 25.9
241.98 2352 1060.8 1387.2 24.7
243.06 2247 1050.6 1356.6 24.7
244.2 2163 1050.6 1326 26.7
245.32 2142 1244.4 1458.6 48.2
246.42 2184 1377 1601.4 58.6
247.55 2247 1560.6 1642.2 50.6
248.66 2247 1081.2 1428 24.7
249.75 2226 1050.6 1346.4 24.7
250.86 2205 1183.2 1570.8 33.9
251.98 2184 1183.2 1744.2 33.1
253.06 2226 1264.8 1428 52.2
254.16 2226 1152.6 1264.8 30.7
255.28 2184 1060.8 1305.6 25.9
256.41 2205 1356.6 1713.6 64.1
257.51 2226 1315.8 1560.6 61.8
258.61 2247 1295.4 1315.8 50.2
259.74 2268 1295.4 1387.2 55.4
260.85 2289 1295.4 1407.6 57.4
261.93 2331 1754.4 1948.2 58.6
263.06 2415 1734 2172.6 81.3
264.19 2478 1723.8 2203.2 93.6
265.27 2520 1346.4 1989 93.2
266.35 2478 1060.8 1387.2 27.1
267.49 2415 1060.8 1397.4 25.9
268.59 2352 1060.8 1387.2 24.7
269.67 2352 1224 1417.8 29.1
270.78 2331 1295.4 1397.4 53.4
271.91 2373 1356.6 1499.4 56.2
272.99 2373 1142.4 1356.6 31.9
274.07 2352 1081.2 1397.4 25.5
275.19 2331 1254.6 1530 63
276.27 2373 1315.8 1417.8 53.4
277.39 2415 1438.2 1581 55.8
278.49 2457 1387.2 1652.4 65.3
279.63 2436 1091.4 1417.8 27.9
280.73 2415 1193.4 1509.6 60.6
281.81 2415 1315.8 1356.6 49.8
282.91 2457 1366.8 1438.2 55.4
284.05 2478 1264.8 1560.6 64.5
285.13 2499 1428 1468.8 53.4
286.22 2499 1142.4 1356.6 33.9
287.35 2478 1101.6 1428 29.1
288.45 2478 1152.6 1499.4 31.5
289.52 2457 1346.4 1540.2 60.2
290.65 2499 1346.4 1489.2 58.6
291.75 2520 1193.4 1397.4 63
292.86 2520 1254.6 1234.2 52.2
293.95 2520 1162.8 1275 53.8
295.07 2520 1264.8 1458.6 57.4
296.14 2541 1356.6 1621.8 66.5
297.22 2562 1152.6 1346.4 37.1
298.35 2520 1101.6 1407.6 29.9
299.46 2478 1183.2 1499.4 35.9
300.54 2478 1275 1336.2 52.2
301.67 2478 1173 1295.4 48.2
302.81 2457 1183.2 1264.8 46.6
303.92 2436 1183.2 1285.2 49
305.02 2415 1193.4 1295.4 51
306.14 2415 1336.2 1499.4 57.8
307.26 2436 1336.2 1489.2 62.2
308.34 2436 1275 1387.2 60.6
309.42 2436 1295.4 1305.6 55
310.54 2436 1326 1346.4 55.8
311.62 2436 1326 1407.6 60.2
312.74 2436 1315.8 1407.6 62.2
313.85 2436 1305.6 1377 61
314.94 2436 1234.2 1285.2 59.8
316.02 2394 1295.4 1448.4 52.6
317.14 2415 1326 1560.6 62.2
318.27 2415 1254.6 1397.4 53.4
319.4 2436 1397.4 1693.2 66.1
320.48 2436 1254.6 1407.6 61.4
321.58 2415 1234.2 1264.8 52.2
322.68 2394 1183.2 1213.8 47.4
323.8 2373 1264.8 1264.8 51
324.88 2394 1346.4 1499.4 60.2
326 2415 1366.8 1591.2 68.5
327.08 2436 1346.4 1407.6 61
328.16 2415 1264.8 1254.6 57
329.26 2415 1305.6 1315.8 57
330.34 2415 1213.8 1224 55.8
331.42 2415 1305.6 1264.8 54.2
332.5 2415 1305.6 1326 57.8
333.64 2415 1254.6 1295.4 58.6
334.74 2415 1254.6 1244.4 55.8
335.83 2394 1305.6 1264.8 54.6
336.94 2394 1305.6 1315.8 57.8
338.05 2415 1346.4 1366.8 58.6
339.14 2415 1285.2 1356.6 62.2
340.21 2394 1285.2 1295.4 58.6
341.31 2394 1295.4 1315.8 58.6
342.43 2394 1295.4 1305.6 59
343.55 2394 1264.8 1295.4 59.8
344.66 2373 1244.4 1234.2 56.6
345.74 2373 1254.6 1224 55
346.81 2373 1264.8 1254.6 56.2
347.89 2373 1315.8 1346.4 59
349.02 2331 1142.4 1346.4 31.1
350.15 2352 1458.6 1703.4 61
351.25 2394 1458.6 1642.2 61.4
352.33 2415 1438.2 1601.4 63
353.48 2415 1275 1305.6 57.4
354.55 2394 1275 1264.8 54.6
355.67 2394 1275 1264.8 54.2
356.8 2394 1285.2 1275 54.2
357.89 2394 1326 1275 53
358.97 2394 1326 1356.6 57
360.07 2415 1326 1356.6 57.8
361.21 2415 1305.6 1346.4 57.8
362.29 2415 1315.8 1346.4 58.2
363.37 2415 1254.6 1295.4 58.2
364.48 2415 1254.6 1244.4 55.4
365.61 2415 1254.6 1234.2 54.6
366.69 2394 1254.6 1244.4 54.6
367.77 2394 1122 1336.2 27.9
368.89 2352 1142.4 1519.8 31.9
370.01 2331 1173 1632 32.7
371.09 2331 1173 1683 34.3
I also noticed this log looked a little wierd, anything out of the ordinary? Group 13 (no idea what it is!!!)
Group C: '013
Inj. Quantity Inj. Quantity Inj. Quantity Inj. Quantity
TIME
STAMP mg/str mg/str mg/str mg/str
0.72 -0.42 -0.16 -0.19 0.78
1.87 -0.45 -0.16 -0.19 0.78
2.98 -0.47 -0.16 -0.14 0.8
4.06 -0.49 -0.16 -0.14 0.8
5.18 -0.49 -0.14 -0.09 0.8
6.35 -0.52 -0.16 -0.12 0.82
7.44 -0.52 -0.16 -0.14 0.82
8.52 -0.52 -0.14 -0.14 0.82
9.64 -0.54 -0.14 -0.14 0.82
10.76 -0.54 -0.14 -0.14 0.82
11.86 -0.54 -0.14 -0.14 0.85
12.98 -0.56 -0.19 -0.09 0.85
14.1 -0.56 -0.16 -0.09 0.85
15.24 -0.59 -0.19 -0.07 0.85
16.32 -0.59 -0.21 -0.05 0.85
17.43 -0.61 -0.24 -0.02 0.85
18.52 -0.61 -0.24 0 0.85
19.6 -0.61 -0.24 0 0.82
20.71 -0.61 -0.24 0.02 0.8
21.82 -0.61 -0.24 0.05 0.8
22.91 -0.61 -0.24 0.05 0.8
24 -0.61 -0.24 0.05 0.78
25.12 -0.61 -0.24 0.05 0.78
26.26 -0.61 -0.24 0.07 0.75
27.37 -0.61 -0.24 0.07 0.75
28.47 -0.59 -0.24 0.07 0.75
29.62 -0.56 -0.24 0.07 0.73
30.73 -0.56 -0.24 0.07 0.73
31.81 -0.56 -0.24 0.07 0.73
32.92 -0.56 -0.24 0.07 0.71
34.06 -0.56 -0.21 0.05 0.71
35.19 -0.59 -0.21 0.05 0.71
36.27 -0.59 -0.21 0.07 0.71
37.4 -0.59 -0.21 0.07 0.73
38.53 -0.59 -0.21 0.05 0.73
39.61 -0.59 -0.19 0.05 0.73
40.73 -0.61 -0.19 0.05 0.73
41.86 -0.59 -0.19 0.07 0.73
42.99 -0.56 -0.19 0.09 0.75
44.07 -0.61 -0.19 0.05 0.73
45.18 -0.61 -0.19 0.05 0.73
46.31 -0.64 -0.19 0.07 0.75
47.41 -0.64 -0.21 0.09 0.75
48.52 -0.64 -0.21 0.09 0.75
49.65 -0.64 -0.24 0.09 0.75
50.75 -0.64 -0.24 0.09 0.75
52.11 -0.61 -0.24 0.12 0.75
53.23 -0.66 -0.21 0.09 0.78
54.35 -0.66 -0.24 0.12 0.75
55.43 -0.66 -0.24 0.14 0.75
56.54 -0.66 -0.24 0.14 0.75
57.67 -0.64 -0.26 0.14 0.73
58.77 -0.64 -0.26 0.16 0.73
59.85 -0.61 -0.26 0.14 0.71
60.95 -0.61 -0.24 0.16 0.75
62.09 -0.64 -0.24 0.09 0.73
63.21 -0.61 -0.21 0.09 0.73
64.28 -0.61 -0.14 0.02 0.75
65.4 -0.61 -0.14 0 0.75
66.5 -0.61 -0.14 0 0.75
67.59 -0.61 -0.14 0 0.75
68.71 -0.64 -0.09 -0.02 0.8
69.82 -0.66 -0.07 -0.05 0.82
70.9 -0.66 -0.07 -0.05 0.82
71.99 -0.66 -0.07 -0.05 0.82
73.13 -0.66 -0.07 -0.05 0.82
74.22 -0.66 -0.07 -0.05 0.82
75.3 -0.66 -0.07 -0.07 0.85
76.41 -0.71 -0.05 -0.12 0.89
77.5 -0.75 -0.02 -0.14 0.94
78.6 -0.75 -0.05 -0.16 0.94
79.7 -0.75 -0.05 -0.14 0.96
80.83 -0.78 -0.09 -0.14 1.04
81.96 -0.78 -0.09 -0.14 1.04
83.04 -0.78 -0.09 -0.14 1.04
84.15 -0.78 -0.12 -0.14 1.01
85.28 -0.78 -0.16 -0.12 1.04
86.38 -0.47 -0.49 -0.09 1.06
87.5 -0.42 -0.64 -0.05 1.11
88.62 -0.4 -0.73 0 1.13
89.7 -0.38 -0.71 0 1.08
90.82 -0.35 -0.59 -0.05 1.04
91.91 -0.38 -0.52 -0.09 1.04
93.04 -0.4 -0.49 -0.14 1.04
94.12 -0.4 -0.49 -0.14 1.04
95.24 -0.4 -0.49 -0.14 1.04
96.36 -0.4 -0.49 -0.14 1.04
97.46 -0.42 -0.49 -0.09 1.06
98.56 -0.42 -0.47 -0.12 1.01
99.64 -0.42 -0.45 -0.12 0.99
100.78 -0.49 -0.38 -0.14 1.06
101.85 -0.56 -0.28 -0.24 1.13
102.96 -0.61 -0.26 -0.24 1.15
104.06 -0.64 -0.26 -0.26 1.18
105.18 -0.61 -0.26 -0.26 1.18
106.25 -0.61 -0.26 -0.26 1.18
107.36 -0.61 -0.26 -0.26 1.18
108.5 -0.61 -0.26 -0.26 1.18
109.57 -0.66 -0.19 -0.33 1.25
110.66 -0.68 -0.19 -0.33 1.27
111.8 -0.71 -0.21 -0.33 1.25
112.91 -0.71 -0.24 -0.31 1.27
114.03 -0.75 -0.24 -0.31 1.32
115.11 -0.75 -0.24 -0.31 1.32
116.24 -0.75 -0.24 -0.31 1.32
117.33 -0.75 -0.24 -0.33 1.32
118.43 -0.75 -0.24 -0.33 1.32
119.54 -0.75 -0.24 -0.35 1.32
120.65 -0.8 -0.24 -0.31 1.36
121.77 -0.71 -0.21 -0.33 1.32
122.88 -0.75 -0.28 -0.28 1.32
124.02 -0.75 -0.38 -0.24 1.34
125.11 -0.71 -0.52 -0.19 1.41
126.19 -0.64 -0.68 -0.14 1.46
127.3 -0.59 -0.87 -0.07 1.51
128.43 -0.56 -0.92 -0.05 1.53
129.53 -0.49 -0.94 0 1.46
130.63 -0.45 -0.92 0.02 1.34
131.75 -0.38 -0.89 0.05 1.2
132.89 -0.35 -0.85 0.07 1.11
133.99 -0.33 -0.78 0.07 1.04
135.08 -0.33 -0.71 0.05 0.96
136.23 -0.33 -0.64 0.05 0.89
137.32 -0.33 -0.56 0.02 0.85
138.41 -0.33 -0.52 0.02 0.82
139.53 -0.35 -0.47 0.02 0.8
140.64 -0.35 -0.42 0 0.78
141.72 -0.38 -0.38 0 0.75
142.81 -0.38 -0.35 0 0.73
143.95 -0.4 -0.33 0 0.71
145.06 -0.4 -0.28 0 0.71
146.16 -0.42 -0.26 0 0.68
147.29 -0.47 -0.21 -0.05 0.75
148.39 -0.49 -0.19 -0.07 0.75
149.46 -0.52 -0.09 -0.16 0.82
150.55 -0.52 -0.09 -0.16 0.82
151.67 -0.52 -0.09 -0.16 0.82
152.78 -0.54 -0.09 -0.16 0.85
153.86 -0.54 -0.09 -0.16 0.85
154.96 -0.54 -0.09 -0.16 0.85
156.06 -0.54 -0.09 -0.16 0.85
157.16 -0.54 -0.09 -0.16 0.85
158.26 -0.56 -0.09 -0.19 0.85
159.38 -0.59 -0.09 -0.19 0.89
160.46 -0.61 -0.07 -0.21 0.92
161.58 -0.61 -0.07 -0.21 0.89
162.66 -0.56 -0.09 -0.14 0.87
163.78 -0.61 -0.09 -0.16 0.89
164.88 -0.64 -0.09 -0.16 0.89
166 -0.71 -0.12 -0.14 0.96
167.12 -0.78 -0.14 -0.05 0.99
168.24 -0.75 -0.24 -0.05 1.01
169.34 -0.71 -0.28 0 1.01
170.43 -0.66 -0.33 0 0.99
171.56 -0.66 -0.33 0 0.96
172.68 -0.61 -0.33 0.02 0.92
173.75 -0.61 -0.33 0.02 0.87
174.88 -0.56 -0.31 0.05 0.85
176 -0.56 -0.31 0.05 0.8
177.08 -0.54 -0.28 0.05 0.8
178.16 -0.52 -0.21 0.05 0.85
179.26 -0.56 -0.24 0 0.8
180.33 -0.56 -0.24 0 0.8
181.42 -0.56 -0.24 0 0.8
182.54 -0.56 -0.24 0 0.8
183.66 -0.56 -0.24 0 0.82
184.73 -0.56 -0.24 0 0.82
185.81 -0.56 -0.24 0 0.82
186.96 -0.59 -0.24 0 0.82
188.1 -0.61 -0.21 0 0.82
189.19 -0.64 -0.21 0 0.85
190.3 -0.61 -0.24 0.02 0.82
191.43 -0.59 -0.24 0.02 0.8
192.55 -0.59 -0.24 0.02 0.78
193.69 -0.59 -0.21 0.02 0.78
194.81 -0.61 -0.21 0.02 0.78
195.89 -0.61 -0.21 0.05 0.8
197.01 -0.66 -0.14 0 0.82
198.12 -0.71 -0.12 -0.05 0.85
199.23 -0.73 -0.09 -0.05 0.89
200.35 -0.71 -0.16 -0.02 0.92
201.43 -0.52 -0.45 0 0.94
202.56 -0.47 -0.61 0.05 0.99
203.69 -0.42 -0.78 0.09 1.04
204.77 -0.35 -0.92 0.14 1.11
205.9 -0.31 -1.06 0.19 1.15
207.03 -0.26 -1.22 0.24 1.2
208.13 -0.19 -1.36 0.31 1.27
209.23 -0.14 -1.55 0.35 1.32
210.35 -0.09 -1.55 0.38 1.29
211.43 -0.02 -1.36 0.35 1.06
212.51 0 -1.2 0.26 0.89
213.61 0.05 -1.06 0.19 0.8
Will get this info in a graph asap, just had a look around the engine bay and have found oil around the joint of a hose on the middle of the TIP, does that indicate a boost leak there!??
sorry to sound like a nerd, but i have a 1999 tdi 1.9 TDi alhambra in the caribbean, we have NO DEALER here again, were can i download the correct software ( vag.com) i think it is? and which is the corrrect cable to buy?
We have been having limp mode problems for the past 4 years, and its a pain. i would like to finally diagnose and fix.
will appreciate any help
feel free to email me
[email protected]
Hi Guys,
Theres a thread in the Altea forum by Zeezmaster about this as well, and were working through a list of possible faults ;) might be worth a read.
Logs aren't that much use to us anyway as you really need to go through the revsfrom 1500 to 4500 at full throttle to get a good picture. Try and log group 2 3 and 11 all together in one log. Then send me your log file to [email protected]
Will try to but as soon as i hit hard boost she goes into limpmode :( Il go as high up the revs as she will go until hitting limp and log it on 2, 3 and 11 tomorrow.
Will also get the pipes off, clean and retighten and maybe replace clamps, it looks like when i had the turbo upgrade done that they made up an adaptor for the turbo to intake pipe which is where the oil is coming from!
Also hearing a funny sound on hard boost but cant explain it! Im hoping its an air leak and not somthing in the turbo breaking up!!!
Thanks for the help guys!!
