SalSheikh
Under the Hood
Sep 2, 2009
2,756
Midlands, UK
guys,
would adding a 2nd intercooler (off a Cupra R) make any difference to a 180bhp auq Cupra?
or is it a waste of money?
also, what sort of gain would be achieved if any?
thanks
wanna try and be discreet hence the wing mounted option.
also, would adding a fmic mean removing bumper etc for access?
£250? is that just for the kit or fitted?
what sort of gains are there bhp wise?
£250 would be a universal self fit...
I think you'll get like 12 bhp on a stage 1/2 map, but you'll get much stronger boost... and much more torque
(I don't actually have one, I am just going by what I've read on other threads)
You need to remove the bumper.
There on point to this I have tried!!!!
1. on a cupra R the inlet manifold faces the other direction.
2. in a cupra R the way the turbo feeds into the intercoolers runs differantly to the cupra
It would be about £250,00 for the 2 intercoolers and the pipe that conects them.
Than you could ether go buying the part of pipeing for the cupra R and a inlet manifold or a lot of fabrecation.
I went as far as I got the the 2 intercoolers (and thanks to a friend for nothing),and stop
here after working the above out.:redface:
About the the agains it depends on how it is tuned and the weather the cooler and less pipe work the better. that why most people i know went to FMIC.
thanks for the info H Man, looks like i wont be spending £100 on a Cupra R set up then.
will look into a FMIC jobbie.
thanks to all who replied.
