2L 16V ABF engine, so how the hell do you go about getting the oil filter off, which angle do you tackle it from that makes it easiest? It looks like an impossible task....
Also:
The rear trim that says SEAT and IBIZA on it..... SEAT Badge in the middle... how do you get the trim off, the two side bits? looks like it clips from either side, and is meant to slide outwards as it has a little 'lug' at each side which would require sliding to the side to remove it..... is it bolted tho aswell somewhere as i cant figure out how its attatched, as theres no bolts holding it on?
Thanks guys and girls
Also:
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
