Heh, so I've done 1300 miles since new on my Leon, and this morning the pressure sensor notices that the right rear tyre has lost some pressure. As I'm on the way to work and it didn't look flat when I left, I drove it to work (8 miles) and then checked the pressures, both fronts are on 40psi, left rear is on 36psi, right rear is on 12psi!!!
When driving it felt absolutely normal and I couldn't tell it had dropped so low, the tyre doesn't even look deflated?! Checked the tyre over and nothing seems to stuck in it, what could have happened to let it get so low?
