Tyres - what do you run?
mrcoyote
See no evil...
Jul 26, 2004
2,624
And what is your recommendation,
bear in mind I'm 43 not rolling in money like some young pube
It depends on what you're after really. Do you want something that'll grip and grip or do you want a hard wearing all round tyre?
I had the P Zero Neros on my Cupra and I have to agree with Miles that they're a bit pants unless it's warm and dry. Perfect for weather down by the Med, but pretty useless for the UK 80% of the time. I'm now running Toyo PX4 all round which again were fine when new and seem to be lasting forever, but they seem to have gone a bit hard and not very grippy almost 20k later.
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,645
SW LONDON
px4's get my vote even though i haven't got em on yet :D i've done nearly 11k in my p-zero's and they're not worth the money spent to be honest
mrcoyote
See no evil...
Jul 26, 2004
2,624
:confused: How are you able to recommend something which you haven't tried? I have to say that when new they were great in the torrential rain down to Spain and some "spirited" driving in Germany, but they've gone a bit crap since then and tend not to grip so well.
mymorph
417
wolves
ive been running bf goodrich gforce profilers 205/45 r16 on my fr. pretty good but hard to get hold of. excellent in the wet which is why i got them. going to try vreidestein next
NickyJam
Mar 17, 2008
1,645
SW LONDON
that's the first negative comment i've read about them and have done a vast search, they are an improvement on the t1r's and so can only be better (as all have said on the web)...and because i'm gettin em next, that's why they get my vote
the fact that they don't grip so well after is normal...tyres offer most grip when they've just worn in (after about 1500miles), after this grip only gets worse due to the lower tread
Seen these mentioned a few times on here, may follow suit:think:
the vreidesteins are quite expensive iirc...however, all reviews seem good
MTIbiza
www.streetmodified.co.uk
Jul 16, 2007
253
Crawley
Yeah the F1 GSD3 do not last as long as the Toyos or others but the grip levels are not to be sniffed at imho
Mike
bubbles1
Nurburgring Lover
Dec 28, 2008
488
Llandudno
I was not that impressed with the goodyear eagle in a 205/45/16 found the toyo t1r much better every where but they were on a 17" wheel. Vredestien sessanta (much better than any thing else i've used but went back to a 205 size due to wheel arch clearance probs) a stunning tyre but only available in a 215/40/17 upwards. Now on uniroyal rainsport 2 on a 205/40/17 AMAZING wet grip and faultless in the dry £100 each fitted:D
Gazb
328
Lisburn, Northern Ireland
I'm surprised some people are getting anything close to 20k out of tires on the front of a tdi Ibiza.
I've always found them to be very sore on front tires and scrub off the inside of the tire very quickly.
Crafoo
Crazy Fool!
Apr 30, 2005
4,528
At home
I had P Zero Nero's on the car from new and the wear on the front's was terrible, I don't think I managed 20k from the two sets I had on the front, the first set were shot after 8-9k. Since then I've had Yokohama Parada Spec-2's on the front, and as said before they are good in the dry but fairly lethal in the wet, and now I have some Toyo Proxes T1-R's on the front which seem to perform pretty well in the wet and dry and are lasting quite well so far, of the tyres I have had I would buy the Proxes again over the others.
Gazb
328
Yeah, on my cupra I got 9k on the front with P Zero Nero's and 7k with some crapy brand tire I had to get, because it was all the garage had in stock and the P Zero Nero's were starting to show wire in a couple of places on the inside of the tires.
I got my alignment checked after that (at another garage) and they said it was 'slightly' out but not enough to cause them to wear so much on the inside.
Crafoo
Crazy Fool!
Apr 30, 2005
4,528
At home
I've had my alignment checked a few times and it's always been right but the first set of tyres I had on my car were down to the metal on the inside edge of the tyre after 9k. If I align my steering wheel dead straight then stand at the front of the car I can see the wheels point slightly away from each other :confused: I've not had any problems with wear on this latest set of tyres though and they must be 4 or 5k old now.
