Update on my problem, BKR7E question 2nd page..
Dec 20, 2007
505
Right firstly my original explanation and problem can be seen here in this thread, along with a video of what the car is doing aswell.
http://www.seatcupra.net/forums/showthread.php?t=152070
Right, today ive been over to see SuperCupra who firstly looked on vagcom and only fault found was car running rich intermitent, which he thinks is something to do with the 4.0bar FPR as he had the same prob and he is also stage 2 revo.
Anyway, next we turned boost down to HB7 T7, went for a drive and everything on VAG COM looked perfect, running 200+ G/s on MAF, CF at 0.0 or slightly fluctuating too 2.0 now and again, but still the problem was there but nothing showing up on the logs etc.
Myself and a few others seem to think that it could be due to spark plugs?, plugs havent been changed for 11k i just found out, and im running 210 bhp on standard plugs. Could that be causing the problem under full load?shown and heard in the vid is the problem http://www.youtube.com/watch?v=i4O5m1sYwOc,
Which plugs can i purchase from halfords that will fit my car and the spec, they dont sell the BK7RE NGK's, are there any other's i could get from there other than ones for stock power?
ALso could it be coil pack, cause that wouldnt show up on vag com either would it ?
Thanks for your time.
Rob.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
200g/s isnt running perfect thats over reading which in turn could be causing you to overfuel.
I just read that your running a k03 so infact thats way off the mark. Most k03`s pull about 160g/s.
505
And does that mean i can increase my timing on revo, or i just need a new MAF
Dec 20, 2007
505
No test i can do at all before i go and buy a new one ?, if i unplug MAF will it still boost upto 22 psi etc..
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Unplug the maf rob...and take it for a spin with it unplugged TCS light will come on but thats nothing...
try it...you maf is well overreadin tho... and there 55quid on exchance for a new one at GSF...
Dec 20, 2007
505
Ok can it cause any problems if its not the MAF and i do it ? like when i plug it back in ...
Rob.
Oct 17, 2006
893
Walthamstow
the test where it was showing pulling 200g/s is enough -
disconnecting the maf i believe gives a default(safe) value of air passing through and gives enough fuel to match it - not sure if it will give you the complete boost but should sort out the boosting issues you have -
when my maf went, it was reading to high and kept throwing car in to limp mode -
disconnected it and boost perfectly and normally - although you will have to clear the enginer light afterwards
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Nope it will log the fault tho as being disconnected..if it runs better then its your maf but you could be havin a few issue like me...
As for spark plugs id go for these Denso Ik22 as these a perfected for mapped 1.8t they run a grade cooler...Was discussing these last night with benny and Phil W...Dont get cheap plugs...
Link: DENSO Iridium IK22
http://cgi.ebay.co.uk/ws/eBayISAPI....m=320193624975&ssPageName=STRK:MEWA:IT&ih=011
splugs and Coilpack can cause problems on full boost aslo so can the maf....How much is yours overboost by?
Dec 20, 2007
505
yeah i need new plugs anyway
SHould i unplug MAF whilst its running ? or before i start the car ?
Dec 20, 2007
505
Unplugged MAF, seemed to be fine only doing it very very very slightly and boosting to 24 psi.
Then going up a hill in 3rd, it did it again, so does that mean its not my MAF Cause it still did it when it wasnt plugged in :(
Gonna get some logs done in a bit
Dec 20, 2007
505
dunno he just sent me a message saying he knows what the problem is when i see him go over to him lol, must be something simple.
