Foxy
200bhp **** member no. 1
Oct 25, 2003
193
Daventry
www.pug306.net
As title. I bought a Golf mk4 one in the hope I could get it to fit. It looks totally different though. So can a few people post pics of theirs please.
S3 strut bruce, direct fit, (ignore the arrow )
The S3 on is a direct fit but you do need to cut a small amount of metal ou of it to allow it to fit around the passangers side bonnet lifter
i wouldn't have thought the golf one would fit as the leon as a A3 front end and golf rear.
So my first guess would be that there would be differences
Bit of a guide here Clicky, clicky -->http://www.seatcupra.net/forums/showthread.php?t=133999
I used 10x25mm cap heads, i'd also recommend you get 2 nerw drill the ones i used were from homebase the "bullet" type a 5mm and a 10mm, as they have a starter bit on the end, and there easy to centralise the bigger drill once you've drilleda 5mm pilot hole...
Funnily enough i was asked that before so heres a pic I prepared earlier in true blue peter fashion...
I filed it flat for about 30mm along the edge where the yellow ring is highlighted, then gave it a coat of satin black
