APR is going to be the educated choice here, but it is really expensive at £600 ish I think. KMD and Autotech internals can be had for half that fitted from various places.
Iv got the Autotech internals on mine reason being as Djhorace said they worked out cheaper
having a HPFP seems to speed up the wear.
Where did you get that info?
US forums, its either directly attributed by the fuel pump or the higher tune of engine, but it seems to be that modded cars without the upgraded pump dont wear as quickly as one with the upgraded pump.
Reccomendations please!
Who has which brand and why did you choose that one?
tbh the way i read it was , people who check their cam buckets for wear are the only ones who will know regardless of the state of tune , it can fail on a completly standard car the same as a fully modded car , the high pressure bit of the fuel pump has no impact on the cam its the pressure , stroke of the pump itself which gives it its rating , still does the same amont of cycles as standard pump.
It is wise to have it checked every 5000 miles or so. Mine is due a check about now, but I have no reason to suspect any problems with it.
I'd say once at every service interval is fine![]()
any decisions yet?
does your software take advantage of uprated fuel pump?
