townz
Hi guys, i am getting a facelift leon fr in 2 weeks, my question is what is the max size usb stick i can insert into the usb slot that the stereo will accept?
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
i have a USB slot too. From what i can make out the number of tracks is only limited by memory however you can only slpit the tracks into a max of 6 folders/albums.
Mine is pre - FL so not sure if its changed for a newer model.
When using the USB is the track information displayed? Or is it just track1,2 etc
It does.. (If you have the Info on the file ofcourse)
it shows artist and song name.
Yes you can format FAT32 with SwissKnife up to 500GB.
The only downside is the bigger sectors compared to NTFS and the max size of a file can only be 2GB - this doesn't matter with mp3s
SwissKnife is free - by compuapps. google should give you the link as the first match.
Finally got mine sorted on Sunday. Brought a 250gb WD Passport hard drive for £44 (its small enough to sit in the tray by the USB and AUX inputs and is powered by the USB). Had to re-format it to Fat32 as mico had mentioned.
Copied around 30gb of music to it yesterday arranged by a folder for each artist (just over 100 artist folders so far), then folders within for each album.
The RNS310 lets you scroll through each folder just as you would with an iPod (only much bigger capacity). So pleased I went for this system when I brought the FR.
Thanks to Mico for the tips on making it work.
