VAC Leak 1.8T BAM
rudgey
Mk2 Leon TFSI Sport '06
Jul 2, 2008
286
near Midland VW ;)
Hi all,
Did a boost /vac leak test on my tt 225 last night (i know it's not a leon) discovered I have a rather large leak in the vac side of things and need some advice on how best to put it right.
7881G9QuGVE7
Here is where said leak is under the inlet manifold - not entirely sure what the hose is (brake vac line?). Can anyone tell me how to fix this - is the only way to replace the pipework (duh! hehe) or is there any mod I can do 'whilst I'm in there' which'll do away with said pipe?
Anyone know the parts numbers of anything I need or whether some silicone hose of ebay'll do?
Thanks!
LeonJamie
47
Mountsorrel
Hi,
I have had the same problem with my MK1 leon, but my vacuum pipes split in half. I looked on the Internet about fixing this however most people bypassed the pipe work altogether. Silicone pipes will cost you a fair bit as well. I'd google about bypassing vacuum pipes, read into it, then decide if it's for you or not.
Hope this helps.
747_727
1,113
Essex
Stick a picture up on here and I will look on etka and see if I can find the part number for you.
747_727
1,113
Essex
Here are the pictures from etka. See if you can work out what one you need. You will have to see if you can work out where the pipe starts that needs replacing and see if you can spot it on one of these diagrams. I was looking at the same pipes on my lcr and I worked out what I needed by printing off the pictures from etka and then looking at my car.
If you need a price let me know what number it is as my version gives a basic price but its not 100% up to date but it gives you an idea.
Shakey1985
10
Hi all I was going to ask the same question I have the same problem on my leon . one thing is this the same on all engine types cause mine is an auq engine
Shakey1985
10
Hi all need some more advice I need to know the internal diam of the hoses in the pic above am looking
Looking at replacing with silicone pipes
Cheers in advance
rudgey
Jul 2, 2008
286
near Midland VW ;)
Thank you 747_727! I ended up popping down midland Vw for them to id the part - they also ordered for me- fitted and woah this baby moves now! Noticed when I was putting it all back together that my suction jet pump had gone too again midland vw sorted me out and way hey! I now have a decent idle!!! Thanks for all the help!
