Vag-com codes help????
joshywoshy
27
Just scanned my 54 1.6 SX Seat Leon with VAG-COM these are the codes any ideas???
Scanned the car about 2 weeks ago now and it said the the coolent temp sensor was faulty but no errors like this and then when scanned it now its bringing up all this? could the coolent temp sensor cause these errors i now they said they had to reset ECU or somthing to get it to work but would this bring up this kind of error?
any ideas?
VAG-COM Version: Release 409.1-S
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01: Engine
Controller: 036 906 034 DS
Component: MARELLI 4MV 4568
Coding: 00031
Shop #: WSC 06402
VSSZZZ1MZ4R123627 SEZ7Z0D2485116
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0013313
Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00041
Shop #: WSC 06402
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1M0 920 902 A
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 04406
Shop #: WSC 00000
1 Fault Found:
49-10 - No Communications - Intermittent
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
1 Fault Found:
Address 46: Central Conv.
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
1 Fault Found:
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
Address 56: Radio
Controller: 1M0 035 186 K
Component: Radio GRO 2 29
Coding: 00401
Shop #: WSC 02302
End --------------------------------------------------------------------------------------------------
:cartman::cartman:
Josh
joshywoshy
27
The only reason i scanned the car is becasue it seems to use up alot of fuel and i thought the coolent temp sensor would change this, it has made a diffrence but it still seems bad on petrol the car starts normal etc.
Jul 12, 2013
248
RETFORD
have you cleared them and scanned it again?
looks like a battery was disconnected at some point if not maybe ecu failure, more diagnosis needed to confirm that though
joshywoshy
27
I've cleared codes and rescanned and no errors found
Thank you
Josh
