Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
Hay lads just been playing with vag com free version till I buy the activation. Anyway I was trying tor eset the airbag light to no avail but did come accross these fault codes, have posted in the vag com area as well but though more ibiza people might be to help anyway here they are:
5 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to B+ - Intermittent
01596 - Shareware Version. To Decode all DTCs
30-10 - Please Register/Activate - Intermittent
41-10 - Please Register/Activate - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
29-10 - Short to Ground - Intermittent
28-10 - Please Register/Activate - Intermittent
any help much appreciated
the thing that is mentioned more than once is that the motor for the temp. flap & the recirculation flap is shorting out ( at a guess, this could be the same thing :shrug: )
Loose wire maybe :shrug:
would this be to do with the climate control / air con system?
you probably won't be able to reset anything or alter any settings untill you hand over some dollar!
where did you buy the vag-com lead from?
Thanks Guinness,
Think i'l order one of those from ebay. Just remembered that i can run windows on my mac so should work fine.
Where did you get VAG COM software from?
cheers
I have very similair. Something to do with the air recirc, EdButler will tell you what's going on :redface:
28-10 - Short to B+ - Intermittent
41-10 - Blocked or No Voltage - Intermittent
Resull I tested with the tiral and bought a vag com liscense today £50 as the exchange rate to $ is bloody class at the min. Nearly £2 to every 1$ so half Price wooop lol
And tom did u solve the problem?
