Hey, I am having yet more problems with my car.
It is now misfiring, suspect it to be the coil packs as one went down when it was mapped last week. This was replaced (still original ones) but the other 3 are on back order and think one of the others have gone.
Symptoms are the car stutters when cruising and apply the throttle gentle, then it will clear up and you can't notice, and then it will be obvious it is only running on 3 cylinders and run like a sack of **** backfiring and pooping.
I've only driven about 2 miles like this as happened last night on the way home. I did conicidentally accidentally drive through a big puddle so could well have got something wet which has caused it
Anyway, i ordered the interface cable over a year ago and have a laptop but never used it. Where can i download the appropriate software from and is it easy to use so i can try and diagnose it and get it fixed before i go back to Jabba to have other things done.
