Azza_
526
South Shields
ok so here goes, decided to do a little log for the first time since i got it mapped, the map is from a company called big fish tuning and was fine when first done.
fast forward a few month and ive decided to have a look see what its like now after ive fitted my fmic, new plugs etc
looking at vagcom 4th gear run to WOT
Code:
Tuesday	1	October	2013	08:38:47:40973	VCDS Version: Release 12.12.0	Data version: 20130910
06A 906 032 HN		1.8L R4/5VT         0002
	Group A:	'031				Group B:	'115				Group C:	'002
		Lambda Sensor	Lambda Sensor	Bin. Bits	Bin. Bits		Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Engine Speed	Engine Load	Injection	Intake Air Mass
	TIME	Current Value	Specified Value			TIME			(specified Value)	(actual Value)	TIME			Timing
Marker	STAMP					STAMP	 /min	 %	 mbar	 mbar	STAMP	 /min	 %	 ms	 g/s
	967.63	1.023	1	        	        	967.93	3520	82.7	1060	1310	968.23	3520	81.2	9.18	54.69
	968.53	1.023	1	        	        	968.84	3560	77.4	1000	1330	969.13	3520	20.3	6.46	25.06
	969.44	0.852	1	        	        	969.74	4480	168.4	2010	2030	970.04	4600	167.7	20.06	149.89
	970.34	0.984	0.969	        	        	970.65	4760	160.9	1940	2060	970.95	4840	159.4	20.4	147.06
	971.25	0.914	0.93	        	        	971.55	5000	154.1	1880	2030	971.85	5080	152.6	19.72	145.86
	972.16	0.906	0.922	        	        	972.46	5200	146.6	1850	1900	972.76	5320	145.1	18.36	144.69
	973.05	0.938	0.938	        	        	973.36	5440	143.6	1810	1820	973.66	5480	141.4	17.68	148.22
	973.97	0.938	0.945	        	        	974.27	5600	139.8	1780	1770	974.57	5680	139.1	17.68	153.64
	974.87	0.922	0.938	        	        	975.17	5800	137.6	1760	1730	975.47	6120	71.4	7.48	37.31
	975.78	1.039	0.922	        	        	976.08	4760	152.6	1940	1860	976.38	4800	160.2	20.4	150.31
	976.68	0.914	0.922	        	        	976.98	4880	156.4	1910	2040	977.28	5000	48.1	3.74	0
	977.59	0.86	0.852	        	        	977.89	4000	12	1000	1130	978.19	3920	12	0	5.83
	978.49	1.991	0.813	        	        	978.79	3920	104.5	2080	1230	979.08	3960	154.9	19.72	136.89
	979.39	0.922	0.914	        	        	979.7	4040	166.2	2080	2220	979.99	4040	160.2	20.4	122.06
	980.3	0.93	0.945	        	        	980.6	4120	160.2	2060	2110	980.9	4160	159.4	20.06	126.69
As you can see that is rubbish, 192.5 bhp roughly (if that)
o i went out again and logged requested vs actual, n75 duty, maf g/s using the ADV measurering blocks
Code:
Tuesday	1	October	2013	20:42:24:40973	VCDS Version: Release 12.12.0	Data version: 20130910
06A 906 032 HN	ADVMB	1.8L R4/5VT         0002
		G002	F3	G114	F3	G115	F2	G115	F3
Marker	TIME	Group 2 - Field 3	TIME	Group 114 - Field 3	TIME	Group 115 - Field 2	TIME	Group 115 - Field 3
	STAMP	Intake Air Mass	STAMP	Charge Pressure - Solenoid Valve	STAMP	Charge Pressure - (specified Value)	STAMP	Charge Pressure - (actual Value)
		 g/s		 %		 mbar		 mbar
	350	22.58	349.4	0	349.71	1000	349.71	1160
	350.91	28.61	350.31	0	350.61	1000	350.61	1180
	351.82	34.97	351.21	0	351.52	1000	351.52	1260
	352.72	34.78	352.12	0	352.42	1000	352.42	1310
	353.63	38.36	353.03	0	353.33	1000	353.33	1300
	354.52	145.19	353.93	86.3	354.22	2080	354.22	1950
	355.44	148.86	354.84	78.8	355.14	1880	355.14	2000
	356.34	153.39	355.74	72.5	356.04	1770	356.04	1780
	357.25	117.44	356.65	73.7	356.95	1000	356.95	1820
	358.15	150.11	357.54	74.9	357.85	1920	357.85	2020
	359.06	146.47	358.46	73.3	358.76	1830	358.76	1820
	359.96	153.64	359.36	71.4	359.66	1770	359.66	1750
	360.87	148.67	360.27	0	360.57	1950	360.57	1470
	361.78	141.92	361.17	80.4	361.47	1920	361.47	2070
	362.67	143.19	362.08	75.7	362.38	1870	362.38	1920
	363.59	146.28	362.98	71.8	363.28	1820	363.28	1810
	364.49	149.17	363.88	0	364.19	2000	364.19	1370
which gives me this, checked timing pull and i get 6 on cyl 4 but the others mostly stay at 0 or 2ish
does anyone have any ideas? could it be a tired maf sensor just under reading? car pulls ok but the butt dyno seems to think somethings a miss
car is going to be mapped asap but i wouldnt expect the FMIC to have that much of an impact on airflow through the maf
crappy logs tbh dude
more data and clear wot run req'd ideally
002,020,115 - check airflow, injector ms, timing CF, requesed boost
001,031,118 - check fueling and boost/n75%
002,112,118 - check airflow, egts,boost/aits/n75%
3rd gear 2k-6.5k where safe to do so
blocks 002,020,115
Code:
Tuesday	1	October	2013	20:50:58:40973	VCDS Version: Release 12.12.0	Data version: 20130910
	Group A:	'002				Group B:	'020				Group C:	'115
		Engine Speed	Engine Load	Injection	Intake Air Mass		Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition		Engine Speed	Engine Load	Charge Pressure	Charge Pressure
	TIME			Timing		TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay	TIME			(specified Value)	(actual Value)
Marker	STAMP	 /min	 %	 ms	 g/s	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	 %	 mbar	 mbar
	0.01	1840	41.4	5.1	14.67	0.3	0	0	0	0	0.61	1880	50.4	1000	1070
	0.91	1920	51.9	6.12	19.08	1.22	0	0	0	0	1.52	2000	47.4	1000	1120
	1.81	2000	42.9	5.1	15.53	2.12	0	0	0	0	2.41	2080	44.4	1000	1100
	2.72	2120	41.4	4.76	14.47	3.02	0	0	0	0	3.33	2160	40.6	1000	1070
	3.62	2200	39.8	4.76	15.56	3.93	0	0	0	0	4.22	2240	34.6	1000	1070
	4.54	2280	30.8	3.4	11.94	4.84	0	0	0	0	5.14	2280	27.8	1000	1040
	5.44	2320	27.1	3.06	11.08	5.74	0	0	0	0	6.05	2320	27.1	1000	1030
	6.35	2360	27.1	3.06	11.17	6.64	0	0	0	0	6.95	2400	27.1	1000	1030
	7.24	2400	26.3	3.06	11.47	7.55	0	0	0	0	7.84	2440	27.1	1000	1030
	8.15	2480	19.5	2.04	5	8.45	0	0	0	0	8.75	2480	12.8	1000	1030
	9.05	2480	12.8	0	6.42	9.35	0	0	0	0	9.66	2440	13.5	1000	1030
	9.96	2440	13.5	0	6.42	10.26	0	0	0	0	10.56	2480	13.5	1000	1030
	10.86	2440	22.6	3.4	10.58	11.17	0	0	0	0	11.47	2480	21.8	1000	1020
	11.77	2520	25.6	3.74	12.72	12.07	0	0	0	0	12.38	2560	24.8	1000	1030
	12.68	2560	25.6	3.06	12.67	12.99	0	0	0	0	13.29	2600	24.8	1000	1040
	13.58	2600	24.1	3.06	12.39	13.89	0	0	0	0	14.18	2600	27.1	1000	1040
	14.48	2600	27.8	3.74	14.61	14.79	0	0	0	0	15.1	2640	52.6	1000	1060
	15.4	2680	58.6	6.8	31.75	15.7	0	0	0	0	16	2760	68.4	1080	1270
	16.3	2840	75.2	8.84	42.81	16.61	0	0	0	0	16.9	3000	97	1410	1330
	17.21	3120	97	11.56	58.5	17.51	0	0	0	0	17.81	3360	129.3	1690	1700
	18.11	3440	118	13.94	76.97	18.42	0	0	0	0	18.72	3760	169.2	2070	2190
	19.02	3960	168.4	20.06	127.19	19.32	0	0	0	0	19.62	4320	167.7	2040	2190
	19.92	4480	166.9	21.08	141.33	20.23	0	0	0	3	20.53	4800	162.4	1940	2060
	20.83	5000	156.4	19.72	146.47	21.13	0	0	0	3	21.43	5280	147.4	1840	1890
	21.74	5400	140.6	17.68	144.89	22.04	0	3	3	3	22.34	5680	136.1	1780	1750
	22.64	5800	137.6	17.34	152.39	22.94	0	3	6	2.3	23.24	6040	134.6	1750	1740
	23.55	6120	132.3	18.02	153.39	23.85	0	2.3	6	2.3	24.15	6360	131.6	1760	1720
	24.45	6440	132.3	16.66	163.08	24.75	0	0	0	0	25.05	5720	10.5	1000	1230
	25.35	4840	15.8	3.4	18.11	25.66	0	0	2.3	0.8	25.95	5080	152.6	1880	1880
	26.26	5000	42.9	3.74	11.69	26.56	0	0	0	0	26.85	4200	12	1000	1120
	27.16	4000	12	0	6.58	27.46	0	0	0	0	27.76	3920	12	1000	1050
blocks 001,031,118
Code:
Tuesday	1	October	2013	20:56:58:40973	VCDS Version: Release 12.12.0	Data version: 20130910
	Group A:	'001				Group B:	'031				Group C:	'118
		Engine Speed	Coolant	Lambda	Basic Setting		Lambda Sensor	Lambda Sensor	Bin. Bits	Bin. Bits		Engine Speed	Intake Air	Charge Pressure	Charge Pressure
	TIME		Temperature	Controller	Requirements	TIME	Current Value	Specified Value			TIME		Temperature	Solenoid Valve	(actual Value)
Marker	STAMP	 /min	°C	 %		STAMP					STAMP	 /min	°C	 %	 mbar
	0.02	2040	99	0	11110101	0.3	1.991	1.047	        	        	0.6	1920	24	0	1020
	0.9	1840	99	0	11110111	1.21	1.991	1.047	        	        	1.51	1760	24	0	1020
	1.81	1520	99	0	11110111	2.11	1.991	0.797	        	        	2.41	1120	24	0	1020
	2.71	1240	98	0	11100111	3.02	1.257	0.797	        	        	3.32	2040	24	0	1010
	3.62	2040	98	5.5	11101101	3.93	0.821	0.797	        	        	4.22	2000	25	0	1010
	4.53	2000	98	3.9	11101001	4.83	0.75	0.805	        	        	5.13	2000	24	0	1010
	5.44	1960	98	-5.5	11101001	5.73	0.836	1	        	        	6.03	2000	24	0	1020
	6.34	2000	98	-3.9	11101001	6.64	1.023	1	        	        	6.95	2040	24	0	1030
	7.24	2040	98	-1.6	11101001	7.55	0.992	1	        	        	7.84	2080	24	0	1030
	8.15	2080	98	-0.8	11101001	8.45	0.984	1	        	        	8.76	2080	24	0	1020
	9.05	2080	98	-2.3	11101001	9.35	1	1	        	        	9.65	2040	24	0	1020
	9.97	2040	97	0	11101001	10.27	0.992	1	        	        	10.56	2080	24	0	1020
	10.86	2080	97	-0.8	11101001	11.17	0.984	1	        	        	11.47	2040	24	0	1020
	11.77	2080	96	-3.9	11101001	12.08	0.992	1	        	        	12.37	2080	24	0	1030
	12.68	2080	96	-3.9	11101001	12.97	1.008	1	        	        	13.27	2120	24	0	1030
	13.59	2120	96	-2.3	11101001	13.89	1	1	        	        	14.18	2120	23	0	1030
	14.48	2120	96	-2.3	11101001	14.78	1	1	        	        	15.09	2120	23	0	1030
	15.4	2120	96	-0.8	11101001	15.69	0.992	1	        	        	15.99	2120	23	0	1030
	16.29	2080	96	-0.8	11101001	16.59	0.992	1	        	        	16.9	2120	23	0	1030
	17.2	2120	96	-0.8	11101001	17.51	0.984	1	        	        	17.8	2080	23	0	1030
	18.1	2080	96	-0.8	11101001	18.42	0.992	1	        	        	18.71	2080	24	0	1030
	19.02	2080	96	-3.1	11101001	19.31	0.992	1	        	        	19.61	2120	24	0	1030
	19.91	2120	96	-3.1	11101001	20.22	1	1	        	        	20.52	2120	24	0	1030
	20.83	2120	96	-2.3	11101001	21.12	1.008	1	        	        	21.43	2160	24	0	1030
	21.73	2160	96	-2.3	11101001	22.02	1.008	1	        	        	22.34	2200	24	0	1040
	22.64	2240	96	0.8	11101001	22.94	0.938	1	        	        	23.23	2320	24	0	1140
	23.53	2400	96	-3.1	11101001	23.85	1.008	1	        	        	24.15	2520	23	2.4	1280
	24.45	2640	96	1.6	11101001	24.75	0.992	1	        	        	25.05	2840	21	19.6	1350
	25.35	2960	96	2.3	11101001	25.66	1	1	        	        	25.96	3240	19	37.6	1400
	26.25	3360	96	0	11100001	26.56	0.922	1	        	        	26.86	3680	20	78.4	2140
	27.17	3840	96	4.7	11101001	27.46	0.977	1	        	        	27.77	4240	18	80	2230
	28.07	4400	96	3.9	11101001	28.37	0.93	0.938	        	        	28.67	4720	18	80.4	2100
	28.97	4880	95	2.3	11101001	29.28	0.922	0.93	        	        	29.58	5160	18	76.1	1940
	29.88	5280	95	2.3	11101001	30.18	0.938	0.945	        	        	30.48	5520	18	72.9	1810
	30.78	5640	96	2.3	11101001	31.09	0.938	0.945	        	        	31.39	5880	18	72.5	1730
	31.69	6000	95	5.5	11101001	31.99	0.883	0.883	        	        	32.29	6240	18	74.9	1700
	32.6	6360	95	3.1	11101001	32.9	0.922	0.938	        	        	33.2	5960	18	0	1350
	33.5	5040	95	7.8	11100001	33.8	0.86	0.891	        	        	34.1	5160	20	77.6	1880
	34.41	5280	96	3.9	11101001	34.71	0.914	0.945	        	        	35	5440	20	72.2	1820
	35.31	5520	95	1.6	11101001	35.61	0.938	0.945	        	        	35.92	5640	20	71.4	1760
	36.22	5720	96	1.6	11101001	36.52	0.922	0.938	        	        	36.82	5840	20	71	1740
	37.12	5920	95	3.1	11101001	37.42	0.891	0.899	        	        	37.73	5840	20	0	1710
	38.03	5360	96	16.4	11110001	38.33	1.569	1.047	        	        	38.63	4720	18	0	1090
	38.93	4720	96	0	11110001	39.23	1.991	1.047	        	        	39.53	4640	19	0	1060
	39.84	4600	96	0	11110001	40.13	1.991	1.047	        	        	40.43	4560	21	0	1050
Blocks 002,112,118
Code:
Tuesday	1	October	2013	21:01:41:40973	VCDS Version: Release 12.12.0	Data version: 20130910
	Group A:	'002				Group B:	'112				Group C:	'118
		Engine Speed	Engine Load	Injection	Intake Air Mass		Bin. Bits	Bin. Bits	Bin. Bits	Bin. Bits		Engine Speed	Intake Air	Charge Pressure	Charge Pressure
	TIME			Timing		TIME					TIME		Temperature	Solenoid Valve	(actual Value)
Marker	STAMP	 /min	 %	 ms	 g/s	STAMP					STAMP	 /min	°C	 %	 mbar
	0.01	1960	14.3	0	5.53	0.3	        	        	        	        	0.6	1840	26	0	1020
	0.91	1760	14.3	0	4.83	1.21	        	        	        	        	1.51	1640	26	0	1020
	1.81	1640	12.8	0	3.92	2.11	        	        	        	        	2.41	1640	27	0	1020
	2.72	1600	34.6	5.44	11.86	3.02	        	        	        	        	3.32	1680	26	0	1030
	3.62	1720	44.4	6.8	15.72	3.92	        	        	        	        	4.23	1800	25	0	1100
	4.53	1840	72.9	8.16	28.42	4.83	        	        	        	        	5.14	1960	24	0	1220
	5.43	2000	51.1	6.12	19.22	5.74	        	        	        	        	6.04	2120	23	0	1180
	6.34	2160	57.9	7.14	24.42	6.65	        	        	        	        	6.95	2280	23	0	1200
	7.25	2360	62.4	7.48	29.81	7.54	        	        	        	        	7.85	2480	22	0	1260
	8.16	2560	62.4	7.48	30.67	8.46	        	        	        	        	8.75	2720	21	0	1280
	9.06	2760	58.6	7.14	30.56	9.36	        	        	        	        	9.67	2920	21	0	1290
	9.97	3000	62.4	7.48	35.97	10.27	        	        	        	        	10.57	3160	21	0	1300
	10.87	3240	61.7	7.48	37.78	11.18	        	        	        	        	11.48	3400	21	0	1310
	11.78	3480	66.9	8.16	44.53	12.08	        	        	        	        	12.38	3680	20	0	1310
	12.68	3800	122.6	15.3	103.22	12.97	        	        	        	        	13.29	4160	20	80.4	2230
	13.59	4360	168.4	20.4	136.25	13.89	        	        	        	        	14.19	4760	18	80.4	2100
	14.49	5000	160.2	20.06	148.28	14.8	        	        	        	        	15.1	5360	18	72.9	1900
	15.4	5520	141.4	18.02	147.25	15.7	        	        	        	        	16	5840	18	71.8	1710
	16.3	5960	133.8	18.36	151.17	16.61	        	        	        	        	16.91	6200	18	74.5	1710
	17.21	6360	133.1	17	158.42	17.51	        	        	        	        	17.81	6240	18	0	1730
	18.11	5720	10.5	1.7	6.47	18.42	        	        	        	        	18.71	4880	17	0	1090
	19.02	4920	28.6	5.44	33.78	19.32	        	        	        	        	19.62	5040	20	76.9	1880
	19.92	5000	45.1	4.08	8.19	20.23	        	        	        	        	20.53	4920	18	0	1130
	20.83	4920	12	0	9.19	21.13	        	        	        	        	21.43	4800	17	0	1070
	21.72	4760	12	0	10.89	22.03	        	        	        	        	22.33	4720	19	0	1060
	22.63	4680	12	0	11.19	22.94	        	        	        	        	23.23	4600	20	0	1060
	23.54	4560	12	0	10.72	23.84	        	        	        	        	24.15	4520	21	0	1060
	24.44	4440	12	0	10.58	24.75	        	        	        	        	25.04	4400	21	0	1060
Hopefully this cn shed a little bit of light on the situation
cheers
looks lean at the top and its pulling timing from 5400rpm onwards because of slight knock, probably from the weak afr
i'm still learning the humble 1.8t ecu so someone more knowledgeable will come along soon I bet
yeah join the club adam, ive spent the night reading up on injection on time, afr's, and what causes knock (i use vpower everytime, bar the odd time im caught out)
the plugs are new and gapped to 0.28 altho ill pull them tomorrow and double check, fuel filter will be changed tomorrow just cause its cheap and probably has never been done, inlet will be getting torn off to check all them horrible pcv pipes for any more leaks.
also going to check and treble check all FMIC pipe work (even tho it meets and exceeds requested boost), as far as im aware from my limited reading the n75 duty cycles look fine?
block 002 injector ontime from reading up at a peak of 20.6ms works out about 83%? if my maths is right (probably wrong tho! lol )
I've got lots of petrol tuning experience just not on 1.8t so I don't know if they can handle it.
I just looked at the lambda request and worked out its in 13's which is too lean for me, fine for the odd 3rd pull, wait till it's in 5th 6th doing too speed runs, yes it has a Egt and knock fuel map but no engine should ever need to use them if set up right,
which then you look and see cf's of 3 at the same point signs to me the lack of fuel is cause the onset of knock but the ecu is clever and is protecting it for you.
this ecu has modelled egt not measured tho
mild looking map
I would run it slightly richer personally but its not disasterous..
Even so no engine should ever rely on protection maps like this one is with the knock correction
Got to be for 95/99 Ron.
A tuned car should be tuned on one fuel and kept to it that's just my opinion, lots of other groups I'm used to tuning like japs and french cars stick totally to Vpower when remapped, I find it strange the vag scene doesn't then cry when they get low power dynos and running issues when using dishwasher supermarket 95ron fuel
ive been pretty strict with my fuel and travel about 3 mile for vpower, but sometimes get caught short and have to use supermarket rubbish, but if they do 97 ron at the pump ill pay the extra for that
they do...
what happens when these are sold on and new owners dont take notice or care about fuel grades vs mapped for
std spec the car can pull a max of 12 degrees timing from hearing knock
Pulls up to 12degrees? I'd still rather it not pull any on Vpower.
I come from ecus that have shite knock control and cars that run on carbs and basic ignition control with. I knock control at all proper fun and games, where you need to tune it right without letting anything help and having to run lamda values of below 0.81 to stop it detonating once it's all warned up properly on a top gear 5th/6th prolonged load
Think it'll stick to using my ears to listen for knock than a sensor that could be giving wrong readings
Poor map as already stated, it's not running much boost so not much of a issue
Wrong readings? lol
I would be trusting bosch knock strategy over your ears from inside the cabin any day :p
ME7 ecu is clever and will try its utmost to keep the engine in one piece.
