Vent Pod for Boost Gauge
hubbly_bubbly
[center][img]http://i374.
Aug 18, 2008
399
Johannesburg, South Africa
Finally got around to designing a vent pods for the Mk1 Leon air vent. This allows for a neat and OEM style fitment for a boost (or other) gauge. I have also designed the pods for 45mm and 52mm gauges. The vent pod insert replaces the stock air vent internals which clip out and the pod is fixed in place by clips in the stock vent surround. The complete vent pods (single/triple) replace the entire housing.
Vent Pod Insert:
Vent Pod (Single):
Vent Pod (Triple):
Here are some other Seat pods,
Mk2 Leon Vent Pod:
Mk4 Ibiza Vent Pod:
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
They look fab mate you done a great job, I don't like how they stick out tho, rather have them flush, great job tho they will defo sell
hubbly_bubbly
Aug 18, 2008
399
Lines are feed through behind the battery. Power is taken from light switch and fuse panel.
Thanks for feedback guys.
BigJohn they stick out because of the angle towards the driver. To make them flush would require the gauge to sit flat against the dash not pointing towards the driver.
Its something that I can look at doing, as an option.
Cheers.
Bigjohn84
May 5, 2015
2,330
Yeh they do look good mate. I think ill stick with trying to get a piller pod. Piller pod is in eye line dont think I wanna look down all the time. Keep up the good work tho.
AmD Stage 1 Map, Forge 007 DV, CDA Induction Kit, GT80 Milltek Sports Cat Back.
