will be ordering 1 of these very soon from what ive heard awesome piece of kit cant wait just need to fit my turbo first lol
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
been searching found this http://forums.vwvortex.com/zerothread?id=4333538
Yeah they look brilliant! Can't wait to get mine running properly!
when's the turbo arriving?
Right ive just had a look,
Black wire - ground
Red/black - the 4 black/violet wires that come from the coilpacks.
Red - the 4 black/violet wires that are coming from ecu or wherever for the coilpacks, the other side of the wires anyway lol.
Blue - goes to the grey/blue wire on accelerator switch. (its wire no.1 on plug)
Yellow - goes to the blue/green wire (the thinnest) on injector 4.
Green - goes to he white/red wire on the clutch pedal.
I did have some problems with mine at first but i think it was due to software as it was second hand so bought a cable and downloaded soft ware and had to invert clutch switch signal, but it is easy with the software.
hope this helps,
josh
callum let me no the income on this pal as im looking into one . but dont want to mess around with wires shorly someone can confirm hes wired it up right .![]()
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
make sure you dont have a dry joint on the 4 wires bundling into the single wire from the WOT box, make sure theyre soldered well...
also which might be the case... id you cut the wire going to one of the injectors, the wire the box uses for the rpm? This needs to be left cnnected and simply spliced not cut, if youve cut it, youll deffinitely get a missfire.
yea, i just mean so in effect the wire is still a complete wire as if its not been cut, but then has the yellow wire still attached...
did you attach it to the injector or the coil signal wire? do you remember which colour wire you attached it to aswell? ill check autodata for the right wires for you...
I had this on my ihi...What a truely outstanding peice of kit it is...
has yours been setted up yet if not why dont you have a word with backdraft alex. he put mine in.If you can get it too work!![]()
