zico900
Hi
The car has no warning chimes when:
1-u open the driver`s door and the engine is running
2-Turn on the igntion
It only has:
1-Seat belt warning
2-Lights on notification
Is there a way to fix this?? by VAG-com maybe...? I did not buy the cable or software but I can go to a service center.....
or should I buy a cable for future small thinges?? and is it easy to use??
Sorry for my english....
1. The engine noise kinda works as the chime in this instance imo
2. that'd be so annoying if my car chimed every time i turned the ignition on.
I complelty agree, my Dad's Astra has a rediculous amount of warning chimes. It's very annoying.
I certinly don't need my car to remind me that the engine is running, as long as theres a chime for the lights being on I'll be happy :)
On a similar note does the new Ibiza still have the terrifying fuel beep?
it also chimes when you are low of fuel
and if it is icy
as for the low fuel beep, im sure its a nice bong like if you leave your lights on rather than an ear piercing beep in the mk4s lol
oh yea forgot that one got mine set at 70mph
as thats the max speed you can drive legaly on the road... lol
1st day i had it i thought i broken somthing cus it was bongin when i went over 20!
really should have had a good read of the manual first!
how do you set that speed?? from the VAG-com or from the car itself??
it also bongs if you start driving and the handbrake is on a little bit, not found anymore bongs though
One other bong i've had is if you're stuck on a hill in the ice and are revving it whilst someone pushes you. Do it for too long and the car bongs, the glowcoil light and the exhaust light and the handbrake light come on.
turning the ignition off and on again sorts it all though.. can only assume it's a "clutch is getting too hot" bong ?
is there one for low washer fluid as ive ran out before and nothing came up on the on board computer (if thats what you call them)
