Hi.......i am currently modding my cupra for more gee gee's and im considering water injection as an alternative to a larger intercooler as i know the gains and benafits are impressive but.......ive never seen it on a 20vt lump before
Does anyone know of this conversion on the vag engine
Craig! said:Would you run an FMIC and Aquamist, Bill? Been thinking about doing it as the lower the intake temps the better!
JKing said:never fully understood water injection. Am I right in thinking its a fine mist of water sprayed into the lntake or is it just water sprayed across the intercooler??
Surely spraying water into the intake is not a good idea
JKing said:cheers bill, good info there. I just allways thought water into the engine was a bad idea, I guess if it's just a fine mist though then it should be ok. Just talking from experience as a friend who had a low air feed for his CAI went through a ford which was deeper than he though. Sucked in water through the intake and killed his engine. Obviously this was a larger volume of water than a water injection system but I thought the same prinicple would apply.
