Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
So after 2 days of down pour here in Glasgow, i need to get fixing my door seals. The drivers footwell is very wet, the front passenger only slightly. Luckily the rears seem dry.
So searching on ebay for "butyl sealant strip" and there isn't any 6mm dia like in DubSteve's Guide way back in this thread.
There is 5x6mm, 6x8mm, 8mm dia and 10mm dia.
Would the 5x5mm be sufficient or would the 6x8mm be too big? Or have people discovered it needs to be a different size now?
You do realise that is 9mm x 3mm not 9mm diameter? It's very thin.
