Can anyone help??
Got a 2003 1.9 Tdi 130 and noticed this morning the water temp gauge read 70 degrees even when the ignition was off!! After the 15 mins driver to work it was reading 120 degrees!!! Opened up the bonnet and oil and coolant levels seems ok, the coolant wasn’t boiling over either. The oil temp gauge hadn’t moved so got the impression the engine was still cold.
Could it be sensor or thermostat malfunction??
