Well my water temperature gauge in my car doesn't work too well so I have bought a new one and I am going to check all the wiring at the same time.
The only thing is a canni find it!! Anybody care to point me in the right direction? :)
Also if I replace it am I going to loose alot of coolant? :shrug:
Thanks,
should be on the right hand side of the engine, sticking into a coolant outlet from the block.
Have some coolant spare if youre changing it and with a cold engine as it will piss all over you. :D
hmm, really, must be higher up in the system on the cupra than the 1.4. glad you got it sorted. where did you get the cts from ?
From good aul ebay! It's genuine though ;)
Hopefully it has sorted it because I checked over the wiring and it all seemed to be ok. I mean it did work sometimes with the old sensor... So don't know weather it will be a new sensor that will sort it as if it went I would have thought it would just go.
Good news that its sorted it mate, i need to change mine as the gauge works sometimes but now and again it drops down to 0 or wont work so hoping by changing this it will sort it for me aswell.
I got mine changed in the end on monday and the car feels like it goes better and im getting an extra 4-7 mpg which is nice :) oh and it fixed the gauge problem :)
