silly isnt it that they say you CAN do it but clearly from everyone try, including myself it not possible to change the mileage BUT if seat can do it there must be a way :censored:
using the correct software and the correct cable/equipment works fine
Vagtacho does work on both counts but 'only' if you use their own cable and software legit
90% of the ripped off ones are junk
i bought a set gti clocks but the mileage is way higher than my originals, i bought the vag tacho software and an obd 2 cable to change the mileage but...
my comp just wont recognise the car :S im not sure what im doing wrong...
anything you can suggest flapper?
check driver for the cable ?
did you get them both from the same place ?
not all the cables work the same way you see
