What did you and your MK2 do today?
Oct 3, 2012
570
Cambridge
Fitted a dash cam, been meaning to do it for a while.
I installed an ignition switched 5v supply in the fuse box, ran the cable up behind the A pillar trim, out the top and mounted one of these at the top of the screen on the drivers side,
http://www.ebay.com/itm/Mobius-Acti...FPS-720P-60FPS-Pocket-Camcorder-/151071891306
I would've liked it behind the rear view mirror but the wipers don't clear the screen so it wouldn't be as effective.
Good review here
http://www.youtube.com/watch?v=7wmIyD1fM4M
That camera looks really good, wanting 1 for some track days
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
A bit premature but found some time today so I prepped the car for winter.
- Full deep wash and cleanse
- intense SRP session working out quite a few surface scratches and blemishes,
- 2 layers of FinishKare 1000P sealant/wax ontop of the SRP.
- windows dressed with TW Ice rain repellant
It was a bit mucky...can you tell where I hadn't washed yet?
Now gleaming again
AndrewJB
Friend to SEAT UK & Cupra Racing
Aug 16, 2007
11,175
485
Maranello
took the LCR to Rockingham for some track time.. it handled alot better than i expected was really impressed
robthebubble
LED & Headlight Master
Feb 22, 2011
1,442
Solihull, West Midlands
Did a bit of plastic welding...rather pleased with the result and probably stronger than the original plastic now that its reinforced with wire mesh! These original FL bixenons will be on ebay before I know it!
J400uk
1,978
London, UK
Will do!, just need some repair tabs for one of the top connectors and one for the bottom and then they are ready to go...say next weekend!
Where do you get the repair tabs from and how much do they cost if you don't mind me asking?
The top connector of mine is damaged and it doesn't sit quite right anymore
robthebubble
Feb 22, 2011
1,442
Rob how do you go about plastic welding?
Sent from my HTC One X+ using Tapatalk 2
You use a flat tipped soldering iron, some fine metal mesh, and some matching plastic to act as the weld. You basically put small sections of the mesh spanning the crack, heat it up so it melts into the plastic and then top up with the new matching plastic. You need a steady hand too otherwise your make a right mess of it!
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Took the leon to view a house and then put in an offer so hopefully they accept so I can get on the property ladder :D
Did the Leon like it? :rofl:
Fitted new LED sidelights to replaced the busted one, then noticed drl's have some segments out....grr .... :cry:
Dose
Fresh plates on over the weekend and took car to SOS motorsport to have the centre box removed. now it sounds as she should. planned a intake for Christmas but ended up winning a k and N typhoon off ebay so map for Christmas:) coming together nice and quick:p
