Hi, got my low trolley jack today, purchased at the Classic Car Show at the NEC on Sunday.
On Whitley road? How does that work? I've got a private reg to put on a car...never done it before
It's next to the regent centre bus and metro station in gosforth.
Have you got the retention certificate for the reg number? If you have all you need is that and your v5 and they do it there and then.
The office closes for good on the 13th December though, after that everything will go through DVLA swansea
Well got my DRL's fitted today, i'll get picks up later, what a pain in the ass it was to feed the wire though into the engine bay!!! Managed to do it without taking the battery out but my hands took a hammering.
The only downside is now i've got my airbag light on due to the fact i took the glove box out & had to disconnect the airbag switch. Im hopeing to get my boot struts on this weekend for the boot pop so there'll need vag-com to make the lock/boot pop so hopefully i can get the airbag light turned off @ the same time.
The drl's are spot on that DRLL2 thingy works spot on.
Car has gone into Winter mode. Triple R Splitter has been removed, 19" OZ replaced with 18" Cupra Orions wrapped in Vredestein Wintrak Extreme rubber, ride height raised slightly and 19" OZ dropped off at my local wheel guru to be repaired/refurbed after the wife curbed them last month. They'll be wrapped in Michelin Pilot Super Sports when they come back.......looking forward to trying them out!
Today I received, and in Monday going to the Workshop to install
[M]ike;4314514 said:
Orderd some Eibachs Sportlines, got them for a bargain. Just need to get them fitted. :)
Do you mind if i ask how much a bargin is? Im after some Eibach sportlines ( there the 40/50mm lowering ones right? ) i was going to order some in the next week or two.:cartman:
