What did you and your MK2 do today?
Leeoncupra
764
191
Halesowen
I hope so, I've already had the cam chain and tensioner done within the last 12 months, but lately having intermittent idle issues/low power and this morning threw an engine light.
To do with timing?
R-tech stage 2,forged engine , 3inch turbo back , revo intake,AC delete- 323bhp 333ft lb
richicupra
1,823
9
To do with timing?
Yup, had it checked and the timing pulley wasn't doing anything and was stuck at something like -27 degrees. Sounded like a BTCC car cycling on idle.
Replaced the chain as a precaution in case it had been stretched by the non-adjusting pulley.
The code I got from Carista was "P0016 CMP Sensor (G40)/Engine Speed Sensor (G28) Bank 1, incorrect correlation"
Leeoncupra
764
191
Halesowen
Did you replace the pulley and tensioner aswell?
And has that solved the issue?
R-tech stage 2,forged engine , 3inch turbo back , revo intake,AC delete- 323bhp 333ft lb build thread: http://www.seatcupra.net/forums/showthread.php?t=440348
ECB
Edward CB
Jun 26, 2013
333
15
Northampton
The bonnet paint had gone horrible after a poor respray in the past (before I had the car) and also had a nasty dent above the grill after a football hit it. So got the dent sorted and thankfully my dad for sorted the paint, done a great job, so dead pleased.
Also someone punched the rear quarter panel outside of a pub, which is now sorted and I’ll polish the panel with the DA over Christmas when I’m off work.
RnPnJ
110
Yesterday i had the inlet valves walnut blasted. They have come out immaculate. Also had the injectors cleaned.
Because_Leon
15
Not a huge amount of effort. I found a kit on good old eBay with vibe speakers..
£45 for the front and another £45 for the rears.
Biggest issue is fitting the door cards in the cold!
I would recommend it. Well worth the money!
RnPnJ
110
Ordered a full BCS system. Gave her an oil change after changing cam follower. Used liquimoly oil very impressed so far.
Ordered some rear discs and pads using ECP promo code
