SRGTD
2,744
1,604
Gave it a quick wash, disgusted by how bad my wheels are with the water getting under the lacquer.
White worm corrosion aside, car looks tidy 🙂.
I dislike diamond cut alloys with a passion! 😡 White wormed alloys spoil the appearance of many decent cars when they get to around 2 years old or older.
Reactions: ray
ray
590
191
White worm corrosion aside, car looks tidy .
I dislike diamond cut alloys with a passion! White wormed alloys spoil the appearance of many decent cars when they get to around 2 years old or older.
I got these refurbed under warranty when I got the car 4.5 years ago, they didn’t even last the first winter. Totally agree it’s a sham, have never kerbed or scraped these in all that time (not even my other half) and they look terrible.
But still, not bad for pushing 9.
zeffania
476
159
Pumped up the tyre again! Getting bored of this. New tyre isn't the cure so on the hunt for a new alloy
Sent from my Pixel 7 Pro using Tapatalk
Walone
1,720
508
Near Heathrow
The garage visibly looked at it, but it's 2 tyres that have lost air since being fitted
I've found in the past that if the area where the tyre beads sit is dirty or a bit pitted this can cause slow leaks, also had problems of leaking tyre valves where the core has not been tightened enough. Depending how fast the leak is I would suggest putting them in one those baths that some tyre fitters have.
Reactions: zeffania
zeffania
476
159
I have been meaning to put it in water. Downside to a sloping drive. Maybe I'll do that before spending out more money
Reactions: Walone
Eskilation
105
26
United Kingdom
a much cheaper solution is to replace the bulb itself with LED but I wanted it my way 😎
need 3x smd led > osram LW G6CP-EAFA-JKQL-1
to do this mod
This is a brilliant mod, much more OEM.
Would you have to hand or be able to look at the part number of the left inner light (with fog light in EU) so I can find and do the same but for a UK car and replace the LED;s ... as I really like this and cannot seem to find a part number. I am so glad I found this as been planning this for a while and wondered if possible....
zeffania
476
159
Looks like the seal on the inside of the rim. Took off the wheel and found 3 areas that bubbled when I sprayed on fairy liquid
Now sporting the space saver look which I quite like
Reactions: Walone
