May sound like a silly question when I spray water around the seal what should I expect to be the the result - if there is a leak?
Defo something not right though it’s a constant reoccurring problem the rear window but yeah the car defo steams up very easily
Will empty car completely this weekend and monitor
If you take out the tailgate trim, there is a flap of metal in each corner from the tailgate (which is easily visible). In my case, 1 side had dirt on it. It was also where water found its way in, and corroded the tailgate lock + connector.
I doublechecked by spraying some water on the bottom of the rear windscreen, in the crease between the window and body and then put some compressed air on it. The water went straight in 🙈
After repairing, it also solved exhaust gases coming into the cabin ever so slightly
Reactions: tracktoy
Reactions: nd-photo.nl
Finally got round to cutting out the back seat middle support bracket (circled in picture) so I can start the process of fitting the rear seat delete kit.
Test fitted today and so far just a little bit of trimming will be needed as this Kit is for a Golf MK7 and its very close but does need a little adjustment.
Santa came early this year 😁 will definitely show how they look inside car once installed!
If anyone is interested in ordering them their PNs are 5FA064200 9DG and 5FA071750 9DG. These one are "Cupra" version, but there are also "Seat" version available which has lighter colors.
I’d love a decent dead pedal cover for DSG - but there doesn’t seem to be a RHD version. I tried a few from AliExpress but they were either too narrow (clearly not for DSG) or just naff quality.
Currently have the brushed VW/audi pedals but I do like the look of the Cupra dark chrome ones!
Reactions: Mo_86
Thanks will take a look this weekend.
Driving me mad even before car was just condensing up whilst trying to defrost.
I also need to get to bottom of this cabin heat issue that is most noticeable during winter and makes defrosting almost impossible.
Dealers replacing charge air cooler next month as coolants leaking into there. But not going to solve my cabin heat issue.
Cold start could be sat in the car for 30 minutes, my record time was 40 minutes back in January. And there will be no heat until car actually physically driven.
And If it snows again in the UK this winter I’m in for a rough time.
Tempted to pass by the dealer on weekend to mention it again and see if can ensure it gets nailed down next month.
3rd winter with this same issue.
Thinking it could be a thermostat thing?
  • Wow
Reactions: Frostybear
