i adjusted mine the other day, awesome different, a good possible fix if performance is down and you've checked your MAF, especially likely if your pedal was removed to reweld it after the clutch pedal welds give way
Don't know, but mine was 90% and a mate of mines was 96.1%. Had a fiddle with mine and hit a max of 96.1% so left it at that.
it was my VAG-COM wich i only got the other day ask said we arnt 100% sure what we were doing but try block 10 column 3,
LOOK HERE
Did you get 100% after adjusting?
didnt vagcom it, just turned it clockwise with a 13mm socket on a ratchet until it tightened up![]()
so is this a posible reason for the different performance on some of the ibiza's? i know some with just revo, claim they can match a ko3s ect.
Could well be, defo worth checking. Still dying to know if peopel are getting 100% though![]()
i got a got laptop,i got a cable..........just need to buy another ibiza![]()
Ok so does it turn freely or stop when its reached max?
I wouldnt mind turning mine now but dont want to mess it up not having vagcom handy to check the % !!
Damn this is like having a button that has you shouldnt press, you know you're gonna![]()
