Used silicone and didn't use enough I think. Leaking even worse now so just gonna bite the bullet and buy the butyl stuff and do it the right way.
Lesson learned I tell thee.
collected my new (seatcupramad23's old) front top strut brace today
trial fit pic.
need to paint the red parts blue and work out how the hell to fit the thing, and how to get the one on the right under the bonnet lifter arm.
trial fit pic.
I recently fitted my S3 strut brace on my LCR. I was lucky enough to buy it of a guy who had it on his LCR - but you will need to take a hacksaw to yours where the bonnet catch is and trim a little away so it fits.
Then you will need to buy M10 bolts, nuts and Spring washers (anti vibrate loose ones!) drill some holes into the suspension tops (jack the car up/take wheel off for easier access) drop bolts through. Then measure how much you will need for the washer and bolt. Then cut off the excess (bolt taken out of the hole at this point!) then drop back in and do the washer and nut. Then dothe bolt up from the top using a socket set. Nice and tight :) job done! Took around an hour for me n my dad to do.
it has a bit cut away already, i got it of a scn member that had it on his leon. i just cant wiggle the bloody thing into place. still need to see how much it will affect my insurance before i fit it, if its too much ill just use....:think:.....:idea: velcro
Put the already cut side down first then the other side. Literrally have to hold it vertical/diagonal to fit it under. Tell your insurance....? Why? Just remove it if you crash or say it's a standard strut brace.
its gunna have bright blue mounting plates and the bar is carbon fibre wrapped, not exactly standard.
I have changed the voltage regulator as my dash board and head lights were flickering when the engine was running £42 pounds lighter but its fixed. And then a treat the car to a good clean and polish looks loads better but now all them dings show up.
fixed my door lock, But no I have a clicking noise when putting up/down my window. Will have to check what it's catching too but its no biggy right now
That brace looks identical mine off my old Leon, had to trim down the mount on the bonnet catch side , best to take the bar off mount the mounts first the adjust the bar to suit it is adjustable
Fitted my spaxs coilovers today :) , been messing with the adjustable dampers all day , like a kid in sweet shop finally got it perfect for road use , feels firmer than my old weitecs , and can go harder still. I over the moon about how these coilovers feel , the ride is perfect can't praise them enough
