Picked this up for my leon earlier.
Also if the silver cupra owner with the Cupra reg plate is on here. It was me with the coach who tooted in the M6 traffic this morning.
Your car looks pukka.
Sent from my GT-N7000 using Tapatalk 2
Got round to fitting my autogauge
Still to refit the vents or make a blanking plate....
Had an issue when plumbed it in, reading -30 and struggling to tick over... Think i may have split the pipe somewhere!! Cnt wait to thread another through!!
Was unsure at first, iv got n249 bypass and put the gauge into the dv- fpr.. Sound right or does it go into the dv-inlet part?? Does it matter which?
Any vacuum source will do. Did you use silicone or the crap they send with the gauge?
The clear crap that came with! :(
Lesson learned.. i have got some 4mm internal polyureathen pipe would that do? i used it as vac pipe on my old celica??
Was it a straight fit? Also octavia or fabia???
octavia mate
straight fit, easy peasy.
the only thing is airbag plugs dont match up. so you will either need to... cut ones from leon seats and join onto octavia seat loom, resistor mod, or vagcom them out
Had my LCR's injectors, inlet valves and combustion chambers specialist cleaned - all done in one fell swoop, took one hour and cost only £89.
It now revs like an N/A engine, totally linear, has much sharper low-speed throttle response - and goes like a frackin' rocket :)
If you're interested in more detail, see this thread - clickety
://s371.photobucket.com/user/gilksy2008/media/018.jpg.html
://s371.photobucket.com/user/gilksy2008/media/019.jpg.html
finally fitted my diy refurbed wheels...........!
not a bad job if i do say so myself.
sorry but post limit wont allow links yet lol
Fitted rear H&R ARB
Did the N249 delete
Serviced the dump valve with new piston
Fitted alloy boost hose
Fitted ECS dogbone mount
Oil change
All gone perfectly smoothly for once. :funk:
Fitted my hybrid turbo and bigger injectors :) just need to take it to Badger 5 to get it set up and have a intake made :)
