Do you really need an entire wishbone? Are you sure you don't just need the bushes?
With both of those in the links you supplied, I don't think you'll be getting Cupra voidless bushes.
Genuine Cupra bushes are about £16 a pair from the dealer, not sure about the entire wishbone though.
You could try asking SERE Motors in the sponsors section for a price on the wishbones.
Well the picture on the second link is for the earlier 6K Ibizas - ie >early2002 - so don't buy that one.
The comment on the non-voided bush is not qute correct, this bush is part of the console that the peg of the TCA fits into.
I assume that you are buying the Cupra TCA as it has been said that they are shorter so should reduce the camber on lowered cars. If that is the case then local main dealer is where you should be heading for - or by post from SERE's (remote main dealer).
I saw a few posts on here saying replacing bushes was a right pain and replacing the wishbone with bushes installed was easier.
so if i just need to replace the bushes which ones do i need, i assume these are right for the back
http://cgi.ebay.co.uk/Polo-6N2-Ibiz...68059164?pt=UK_CarsParts_Vehicles_CarParts_SM
ive found when i look for stuff on ebay there is alot of kit for ibiza's up to 2002 but nothing after, why is this or does the MK4 ibiza have another code or name i need to use?
if someone could recommend or drop me a link for the front bushes i would appreciate it.
DO NOT buy those Powerflex bushes, they are for the 1999-2002 6K Ibiza, yours is newer than that, known as the 6L.
There's no point shopping around on eBay and the like for these bushes, they are only about £16 a pair for genuine ones and I doubt you'll get them cheaper!
You can also get them from Awesome GTI if for some reason you can't go to the dealer.
Clicky
