v5r
tdi sport 130 has pulled to the left since new and now worn the inner edges of the front tyres badly. Had 4 wheel alignment carried out about 6mths ago and has made no difference. The place I used said there was no adjustment for caster/camber...
read some threads that you can loosen the sub frame and adjust that way, tried it today and you can get alot of movement... Can anyone recommend some where in or around aberdeen to get this sorted, need somewhere with 4 wheel alignment equipment and the skill to sort it out once and for all...........
is there any way to measure these angles diy????
