Wheel Bearings & Brake Discs
Heavy
79
Peoples Republic of Teesside.
On my 1999 Cupra Sport the rear wheel bearings are droning away. There is also play on each side. The rear brake discs are also quite worn.
I plan to keep the car long term so want to use decent quality parts but also like a bargain.
So, any reccomendations for suppliers/makers to use and avoid?
Is the selction of parts straight forward or are there different types covering this model/year?
Also, if I was to do the job myself any tips or help appreciated.
Cheers.
moink10
62
Ludlow, Shropshire
i did these about month ago, pretty easy job to do really. If you have ABS be careful in taking the rings off the old discs dont want to bend them. use plenty of grease on bearings and make sure you put outer casing on them, I had to put a thick towel over them and bang them in with a rubber hammer.
