Can you buy spacer kits that are 10mm front and 15 rear or would i have to buy a set of each?
no need to spend that much mate. give ESP Engineering a ring. I bought mine from them.
They're hubcentric cnc'd aluminium and are really good quality. think i paid £110 for all four, 2x10mm and 2x15mm. this included longer bolts, you'll need longer lock nuts though. give Bill a ring at badger5 for these.
esp engineering 01892 613292 ask for Liam
cool, cheers for that matey!!! one thing though after putting spacers on, can it damage/wear drive safts & wheel bearings?
Ok just rang ESP Engineering to enquire about purchasing some wheel spacers and one of the questions they asked me was.....do i know the Bore Size & Hub Diameter?........Any ideas?
I have a 54plate LCR running standard 18" wheels.
pcd 5x100 bore 57.1
Like Lee69 says. I've never heard of issues with wheel bearings etc. 15mm wont create a huge amount of mechanical "leverage"
Cheers matey, £70 for spacers ;-) so now just need to get some new bolts as ESP don't supply them apparently ;-(
Is Badger5 a member on here?
cheers for all your help peeps & sorry about the daft simple questions..................well i say simple haha simple to you guys ;-)
p.s 1 last question......
As my front are going to be 10mm wider and rears 15mm wider is it as simple as the wheel nuts needing to be an extra 10/15mm longer than standard ones?
Martin
yep, but you'll have to cut the locking nuts down slightly as they are usually a bit longer than needed. iirc bill will supply you with a set of four that will be long enough for the rears. obviously the fronts are 5mm less so you'll need to cut them down accordingly.
When I got mine from ESP they supplied the bolts with the spacers so i can't comment on Bills non locking wheel nuts. they may need cutting down for the fronts but I really dont know. I'm sure he'll advise you.
hope this helps
