wheel width???
Mark@VAGWORX
SEat Regular
May 15, 2003
401
Nr Colchester, Essex
ibizacupra said:
adjusted the gammer correction now.. brighter and cropped.
The wheels stick out of the wings dont they?
You said ....
"I'm running 7.5x16 with 20mm spacers on the front and 30mm spacers on the rear"
20mm per side front spacers and 30mm per side rear spacers.. Is that right? on ET36 rims in 7.5J x 16
Nice one Bill.
Yeah, 20mm per side front and 30mm per side on the rear.
They stick out a tad, but the tyres are stretched on so still inside the arch.
r1cky
Banana Rama cupra car
Oct 12, 2004
222
im running 8x17 front (ET ?) and 9x17 rear (ET 25) both with stretched tyres lowered 35mm.
no problems here
Deleted member 9043
@ ricky,
so no arhes mods or anything? and would you look maye with a little mirror wat your ET is on the front?
becouse it saves me alot if i can order the right sizes of 17" wheels that fit without having probs you know
and maybe some good pics of your wheels?
i think they look sweet
grtz
r1cky
Oct 12, 2004
222
yes ill have a look at the ET for the front for you tomorrow,
the wheels are these Keskin KT3 with stretched tyres.
r1cky
Oct 12, 2004
222
i havnt done any arch mods but im not sure if the previous owner did the rears as the metal inner arch 'lip' is tucked right round, most cars are like an 'L' shape inside the arch but mine looks like the arch has been rolled. or are all ibizas like this?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
mk3 ibiza's are rolled edge compared to mk2's
9x17 on the rear is well phat.. stretched tyres tho..
I need to run 235 or 245 on my 8x17 for maximum tyre on the road for grip
mine are tiny by comparison... LOL
still want to retain my rear spacers tho for square track front/rear
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
There is absolutely no way you are going to get a 8x17 and a 235+ tyre in your arches without modding them (and be able to turn the steering / have some suspension), and its mid Dec....tick tock, tick tock
Ave it
Rob
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Ave it
Rob
Got my top mounts ordered now & springs (selection).. as blanks so I can choose how to fit em and what to set them to. :) Not overly confident in their sleeve nut if thats what Kev had on his.. :blink: Tick Tock indeed... EAK!
brakes to fit, actutor to setup and fit. ARGHHH..,
Tim had his 235's on his 8x17 rims (et35 mind you) and went ok.. I have 7mm less offset so will stick out further than him, and he ran no spacers on the rear.
I can feel me getting physical with the panels LOL
amazing these guys have got wide wheels and spaced out so much... they stick out, which aint good (or legal for c'ship) but it has surpised me.
was trawling thru some piccies on my puter, and found snookies motor.... how fecking wide are those arches!! :D :D :D :rock: :rocker: :cheeky:
RobT
Full throttle trip
Nov 30, 2001
2,558
10
Congleton
Yes tim has....but he also has no suspension......
At the ring, my wheels were rubbing on 205/45/16's on a ET27 7.5" rim !
kev's top mounts are not a good design IMO - and indeed the whole lot collapsed at curborough - the sleeve nut does not fit well enough IMO - should be easy enough for you to get some made with your machining fella
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
aye on the suspension travel point... got some springs in lengths to try, not too stiff from where I am currently. (broken rear spring anyhow when I did combe. prolly did'nt help brake balance and chassis stability.. OSR broken, NSF locking under braking.. maybe connected.)
Yea I am getting them as blanks too so I can choose what and where to drill them for desired fitting.. machining not going to be a problem for me. :D
r1cky
Oct 12, 2004
222
yeah the wheels are on just need to take some pics! just dont get time during the day then its dark when i come home :(
cupra44
260
this is pretty confusing!! i'm after fitting 7.5 on the front and 9 on the rear 17's, what offset should i get my wheels inn? also am i gonna need spacers? Arches rolled maybe? I want to do the stretched tyre thing too also in the process off lowering the car. :confused:
cupra44
260
also please could somebody explain offset too me i know its measured in mm, but not sure what its actually measuring :confused:
r1cky
Oct 12, 2004
222
you wont need to fit spacers on the rear if your running 9" at the back.
im running 8" front and 9" back and they are nice and level with each other.
8" dont catch on full lock or anything no problems at all with the offset i have (need to check what the offset is tho,l cos ive forgotten)
my arches have not been rolled at all but lowering more than 35mm could do with some mods as mine catches slightly with someone in the back
i went for the 8" rather than 7.5 as i wanted to keep the larger stickey out lip on the wheel. the thinner the rim the less lip you get on these euro style rims.
r1cky
Oct 12, 2004
222
oh and my wheels wont fail MOT as they are perfectly level with the bodywork and the tyres (due to being stretched) are well in under the arch
cupra44
260
so 8x 17 will be ok on the front without spacers? i'm after some keskin wheels myself the kt5's so i would like more of a lip on the front, 8's it is then :D thanks for the advice, if u find out the offset on the front wheels please could let me know. thanks again
