RossyB Guest Jun 20, 2007 #1 What did any of you do with the vacuum hose that connects to the original airbox? As ive now got the secondary air fault code coming!? R
__B3NNY__ OEM with a 'Twist' May 5, 2005 3,449 1 Oxford Jun 20, 2007 #2 If you mean the black hose that connects to the front of the box? I think most people have brought a small filter to connect to it. David.
RossyB Guest Jun 20, 2007 #3 thats the one mate, ok will look at doing that, will the fault code stop coming up if i do this?
Havok316 Boost Junky Jun 6, 2006 1,220 0 Weston-super-Mare Jun 22, 2007 #4 youll need to slap on a filter over the air pump feed which was connected to the airbox. I put on a red Pipercross one from halfys £15
Dan Cupra R The Yellow Sub May 2, 2006 1,514 0 Reading Jun 22, 2007 #5 I still get that fault now (I have a dynatwist which is similar to a bmc) My secondry air pump is just disconnected. Ive got the fault but the car still performs fine, I wouldnt worry
PhilW Nov 2, 2004 9,334 0 South Wales Jun 22, 2007 #6 Just leave it dangling or bin the whole system.
