where to order a hybid K03s?
nick s
256bhp & 282lbs/ft
Dec 9, 2005
396
on a k03s, no chance!
peak power isnt everything, far from it infact !
i don't mean that! :cartman:
i mean with the bigger turbo. and all my parts ihave with my K03s but adding and mapping the bigger turbo!
and as for mine making 256bhp on a K03s, maybe the forge actuator, and boost hitting 27psi and holding 20psi for a while had something to do with it? although that only lasted a month :D
May 2, 2006
2,758
and you told me that because???
very much doubt you can get 280bhp from a standard 70mm tip, maf etc ...you would need a uber bigger turbo that utilises your k03s parts, ie same tip, maf, injectors etc .. which i think is doubtful as bigger turbo's normally mean bigger parts to go with it
nick s
256bhp & 282lbs/ft
Dec 9, 2005
396
i didn't tell YOU that. i was aiming it at acid as he was saying about the fact i have 256bhp being questioned. i will admit it's probably not accurate. but if Jabba's roller's aren't accurate, what power have the boys who have only had a re-map @ jabba, and think there running 200bhp really running then?
i'm not saying what i would or would not achieve, hence why i asked! ;)
thanks for the info though. all i'm after really is a turbo that will hold the power to the redline and not tail off.
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
If your after good power reasonably cheap that holds too the redline then go GT2X.
I love mine, it has masses of shove all the way up the revs. :D
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
just out of intrest how much would you say its cost to get your gt2x all setup and running including the kit? if you dont mind sayin :)
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
From a standard engine you will need the following:
GT2X Kit £999
ATP Manifold £ 300
2.5" DP & CAT £ ~400
Full Exhaust system £ 250>
FMIC £ ~600
S3 TIP £ ~100
S3 Injectors £ new ~90 each, second hand £ ~70
4 Bar FPR £ 45
S3 MAF £ 75
Large CAI £ 150 - 200
Evo heat sheild £ 80
Remap £ 500
Thats all i can think off at the minute.
nick s
256bhp & 282lbs/ft
Dec 9, 2005
396
matt - where's the best place to get the GT2x from? i rang star performance, but they only offer a drive in, drive out service for £1500, plus there in scotland i think!?
May 2, 2006
2,758
£1500?? thats good
when i foned them months back when matt first had his done i think he was quoting £2500 for the drive in drive out service?? when did you get that quote?
Essex_Cupra
466
What does the £1500 include? If it includes everything fitted and running and you just need a map thats pretty cheap
nick s
256bhp & 282lbs/ft
Dec 9, 2005
396
that's £1500 just to supply and fit the turbo. nothing else. no other parts etc. i got that price yesterday.
nick s
256bhp & 282lbs/ft
Dec 9, 2005
396
hmm. nice idea. are they in the states? i could even get it over here for free seeing as i work for a freight forwarder :D
just quickly, are these the codes for a normal K03s?
turbo casting IF 5304 101 5095D
Tag 06A 145 703C
Tag KO3-022/97791
