which DV for loud whoosh?
Dyscontinued
1,142
Leeds
Ok two things.
1) What does drilling the air box do?
2) How come buses and trucks do that when they're diesel? Thought you didn't need a dump valve on a diesel?
gazR
CUPRA
Apr 25, 2009
418
Derbyshire
1. increases air into air box and makes a louder induction noise
2. its probably not a dump valve you can hear on a bus its more likely a safety valve on the air tanks for the brakes/suspension so the tanks dont blow up
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Honestly mate, you wont get a load whoosh from a vag engine unless you want to go into limp mode after.
The best way is to either mod your airbox or fit an open cone filter with a Forge 007
I do, I use a GFB 50/50 and never gone into limp mode, i also use an Apexi mushroom filter.
danny20vt
going back to basics
That's correct on that one, depending on the weight of the truck/bus, the air tank pressure is around 12 bar (imagine that amount of boost!)
I have had one of the valves fail on me and it doesn't half go with a bang!
gazR
CUPRA
Apr 25, 2009
418
Derbyshire
should be right danny i used to work in a bus depot ;)
