Which engine should I use?
Which engine in the Cordy?
  • 1.8T running 270bhp
    Votes: 20 44.4%
  • VR6 blinged up...
    Votes: 25 55.6%
  • Total voters
    45
Pabs
5,936
Basingstoke
vr6 mate - 1.8 is too common and just doesnt seem to impress much anymore. I love em, but vr6 just sounds nicer in both name and actual noise :)
CupraR-Rog
Just Cruising...
Jul 19, 2003
2,291
West Somerset
Pete, like I've been telling you for ages...
VR6!!!!
As has been said, you could always supercharge it!!
Just imagine the sound of that with a bling cone filter... (and then consider the loss of power from hot air, so leave that bit for shows ;))
Icecavern
6,212
Berkshire, UK
www.icecavern.com
Well the VR6 will be cheaper for sure. The wiring and plumbing doesn't bother me as I doubt it's that much different either way. But a 20vt is gonna cost £1500+ a complete VR6 golf can be bought for that much.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Doesn't matter really - it's not like the car will be the daily driver....... less electrogubbins to go wrong too.
Glenn
513
I've got a Corrado VR6 in addition to my Ibiza so I've got plenty of experience with both engines. My advice based on the assumption that it won't be used as a trackday car is :
If you want much more than 200bhp, get the 1.8T. Getting a VR6 to 250bhp+ will cost you £2K onwards using a supercharger and it's not plug 'n' play - the owner of the best supercharged Corrado VR6 is a mate, I've driven it plenty & know all the pitfalls. You can get the same, more consistent, power from a remapped K0-4 1.8T with better low-mid range torque. If you want to go over 300bhp, both will cost about the same to do properly but the VR6 won't need internals, other than a CR drop, until about 350bhp+. For your apparent purposes, get the VR6 with the intention of leaving it N/A, fit & forget. If you want to mess about with it , you'll get better bang-per-buck from the 1.8T.
If you go for a VR6, try & get a 24v 2.8 from a V6 4-Motion if possible and use an 02A gearbox for FWD. If a 12v is all you can manage, try to get a '95-on 2.8 with OBD2 management. Don't waste your time with the 2.9 Corrado ABV engine - the extra 69cc isn't worth it and the late 2.8 are just as powerful with much better management. If you get the 12v VR6, while it's out of the car, drop the gearbox off and replace the timing chain tensioners and guide rails - the parts aren't that much but the labour stacks up if done later when in the car.
In all cases use the stock ECU, aftermarket management will just add unnecessary cost.
